Layer Transparency for LiveMapsWidget in Flex 2.2
1485
7
01-14-2011 06:48 AM
JamesKo
What happened to the Layer Transparency option in the LiveMaps Widget in the Flex 2.2 Viewer?
In version 1.3, users were able to change the transparency for each layer...any help would be appreciated.
RobertScheitlin__GISP
James,
    I guess you are taking about the layerListWidget in 2.2...? Well anyway the transparency slider thing was overlooked for some reason. I did create a TOC and legend widget that has an opacity slider for all map services.
http://www.arcgis.com/home/item.html?id=e2cb71d5c04d40d19e9f945ae0db7ce8
JamesKo
Thank you Robert! As always, your presence on this forum is greatly appreciated.
JamesKo
Robert,
I'm having trouble getting this widget to work. It compiles without problems but I'm getting an error message at line 292: function getFeatureResult, filterOutSubLayer (Error #1009: Cannot access a property or method of a null object reference.)
Any ideas?
fyi, I'm using the uncompiled version.
James,
what does your TOCWidget.xml look like?
JamesKo
<configuration>
<labels>
  <visibilitylabel>Layer Visibility</visibilitylabel>
  <legendlabel>Show Dynamic Map Legend</legendlabel>
</labels>
<tocSettings>
  <expanded>true</expanded>
</tocSettings>
<LegendexcludeLayers>
  <LegendexcludeLayer></LegendexcludeLayer>
</LegendexcludeLayers>
<excludeGraphicLayers>true</excludeGraphicLayers>
<excludeBasemapLayers>true</excludeBasemapLayers>
</configuration>
James,
   Do you have layers in your main config.xml that are type="feature" and are pointing to a non 10 server?
JamesKo
Robert,
That was it! I had one layer of type "feature" pointing to an incorrect service.
Thank you very much for your time.
James
