Labeling FeatureLayer
4168
6
10-27-2011 08:30 AM
KarenRobine
I'm trying to dynamically generate a FeatureLayer and have it automatically labeled. I used a CompositeSymbol as follow.
The correct line, polygon or marker symbol shows but the label doesnt appear.
Ideas?
Code follows:
//Define the Feature Layer:
var url:String = "http://<mymachine>/ArcGIS/rest/services/TestBookmark/MapServer/";
url += txtLayer.text;
featureLayer= new FeatureLayer(url);
featureLayer.id = "Karens Feature Layer";
featureLayer.name = "Karens Feature Layer";
featureLayer.outFields = [txtField.text];
if (featureLayer)
featureLayer.addEventListener(LayerEvent.LOAD, featureLayer1_loadHandler);
//In load handler:
var fLayer:FeatureLayer = FeatureLayer(event.layer);
var symbol:Symbol = fLayer.symbol;
var txtSymbol:TextSymbol = new TextSymbol();
var txtFormat:TextFormat = new TextFormat();
txtFormat.bold = true;
txtFormat.color = 0x0000FF;
txtFormat.size = 16; //if null, 12 is uses
txtSymbol.textFormat = txtFormat;
txtSymbol.placement = TextSymbol.PLACEMENT_MIDDLE;
txtSymbol.textAttribute = txtField.text;
var compSymbol:CompositeSymbol = new CompositeSymbol();
//following if symbol is line:
var sls:SimpleLineSymbol = new SimpleLineSymbol();
sls.style = SimpleLineSymbol.STYLE_SOLID;
compSymbol.symbols = [sls, txtSymbol];
//apply symbol to layer and add to map
fLayer.symbol = compSymbol;
map.addLayer(fLayer);
WilliamBailey
posted same question awhile back...
http://forums.arcgis.com/threads/41494-Add-labels-to-featureLayer
no replies, I'll be watching here too.
KarenRobine
Dynamic Feature Layer labeling doesn't seem to be possible. I don't think it's supported in REST, in general.
But you can do it as a Map Tip. I think that's the way I'm going to do this.
WilliamBailey
I am currently doing just that... Map Tips... problem is Map Tips don't print
I find it hard to believe there is no way to label a FeatureLayer????
TracySchloss
Honored Contributor
I have been using a PopUpRenderer for labeling my featurelayers.  I have the fields I want in an array.  Then I populating the popup with the fields from it.  Here is the section of code where that is happening:
featureLayer.outFields = outFields.split(",");
var pFieldsArray:Array = new Array();
 var popUpInfo:PopUpInfo = new PopUpInfo;
  for (var j:Number = 0; j < featureLayer.outFields.length; j++) {
   var pFieldInfo:PopUpFieldInfo
   pFieldInfo = new PopUpFieldInfo();
   pFieldInfo.fieldName = featureLayer.outFields;
   pFieldInfo.label = featureLayer.outFields + ":  ";
   pFieldInfo.visible=true;
   pFieldInfo.format = new PopUpFieldFormat();
   pFieldsArray.push(pFieldInfo);
   popUpInfo.popUpFieldInfos = pFieldsArray;
   var popUpRenderer:ClassFactory = new ClassFactory(PopUpRenderer);
   popUpRenderer.properties = {popUpInfo:popUpInfo};
   featureLayer.infoWindowRenderer = popUpRenderer
AndrewThomas
We are currently trying to label feature layers also.
The approach we are taking is to add textSymbol graphics to a graphics layer.
Crude code:
    var featureLayer:FeatureLayer = event.target as FeatureLayer;
    var features:ArrayCollection = featureLayer.graphicProvider as ArrayCollection;
                                var labelGraphicsLayer:GraphicsLayer = new GraphicsLayer();
    map.addLayer(labelGraphicsLayer);
    for(var i:int=0;i<features.length;i++)
     var g:Graphic=features.getItemAt(i) as Graphic;
     var x:Number=g.geometry.extent.center.x;
     var y:Number=g.geometry.extent.center.y;
                                        var geomPoint:MapPoint = new MapPoint(x,y,map.spatialReference);
      var textSymbol:TextSymbol = new TextSymbol();
     textSymbol.color = 0x00ff00;
     textSymbol.text = g.attributes["TITLE"];
     var textGraphic:Graphic = new Graphic();
     textGraphic.geometry = geomPoint;
     textGraphic.symbol = textSymbol;
     labelGraphicsLayer.add(textGraphic);
This seems to work but we've still got a bit of work to do around positioning ( no overlapping labels etc)
Having said that, I think I might explore PopUpRenderer as Schlot suggests. That may handle it all better.
If I remember, I'll update this post with our result.
Andrew
Wellington, New Zealand
TracySchloss
Honored Contributor
The PopUp does just that.  It pops up when the user clicks on a feature.  So if you were wanting to generate labels as you might through the Desktop, you would need to approach it differently.
Tracy
