label issue and graphic overlap
1259
05-25-2011 12:20 PM
abukhan
HI:
I am having two issues:
issue 1:
I showed tract polygons on the map using featurelayer..I showed the tract number for labels..
I used tract geometry.extent.center.x, and geometry.extent.center.y as the mappoint and used these mappoints for labels(with symbol set to textsymbol)
Problem happens when we encounter such a geometry where center falls outside the polygon geometry..
In that case , the tract number shows in outside the polygon and difficult to know which one it belogs to..
Is there a way to fix it ??( I mean to get a mappoint that always falls inside the polygon..Note there is an algorithm to determine whether a point is inside a polygon by finding out if i crosss the boundary in odd number, but I can not implement that because I donot have points that comprise that polygon and also it will be killer for performance)
issue 2:
Two graphics layer --both layers got icons... Some of the icons in one layer falls on top of the icons of the other layer...Is there a way to separate them out?
Abu Khan
MehulChoksey
For issue 1: you might want to use labelPoints method of GeometryService.
http://help.arcgis.com/en/webapi/flex/apiref/index.html?com/esri/ags/tasks/GeometryService.html&com/...
But this would mean one more call to the server.
