KMLLayer getLegendInfos
2705
08-02-2011 01:21 PM
RobertScheitlin__GISP
API Team,
I am struggling to to the KMLLayer.getLegendInfos procedure...
Here is what I am trying so far:
var kmllayer:KMLLayer = new KMLLayer("http://explore.data.gov/download/db3a-9tgn/KML");
kmllayer.getLegendInfos(new AsyncResponder(kmlLegendResult,kmlLegendFault,null));
private function kmlLegendResult(lInfos:Array, token:Object):void
            var llInfo:LayerLegendInfo = lInfos[0] as LayerLegendInfo;
            const layName:LegendDataItem = new LegendDataItem();
            layName.lname = llInfo.layerName;
            layName.id = Number.NaN;
            layName.label = llInfo.layerName;
            layName.minscale = llInfo.minScale;
            layName.maxscale = llInfo.maxScale;
            const lClass:LegendDataClassItem = new LegendDataClassItem();
            for(var ll2:int =0; ll2 < llInfo.legendItemInfos.length; ll2++){
                var lli:LegendItemInfo = llInfo.legendItemInfos[ll2] as LegendItemInfo;
                lClass.symbolitems.push(processRenderer(lli));
                layName.legendGroup.push(lClass);
            _legendData.addItem(layName);
            FlexGlobals.topLevelApplication.dispatchEvent(new Event("legendDataLoaded$"));
        private function kmlLegendFault(evt:FaultEvent):void
            trace(evt.message);
legendItemInfos is always 0
Is this something that just does not work yet?
SarthakDatt
Robert,
The KMLLayer is different than other layers in that it only sends the request to load itself(kml data) if it is added to the display list(map). The rest of the layers make the initial(map service info) request even if they are not added to the map.
In your case, you can check for the layer load event and see that it is never fired, hence there is no legend info.
Add the KML layer to map and try again. Should work.
Hope that helps.
Sarthak,
  Thanks for the response but I believe there is an issue here is a very simplified test app:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               xmlns:ags="com.esri.ags.*"
               xmlns:esri="http://www.esri.com/2008/ags"
               minWidth="955" minHeight="600">
    <fx:Script>
        <![CDATA[
            import com.esri.ags.events.LayerEvent;
            import com.esri.ags.layers.supportClasses.KMLScreenOverlay;
            import com.esri.ags.layers.supportClasses.LayerLegendInfo;
            import com.esri.ags.layers.supportClasses.LegendItemInfo;
            import mx.controls.Alert;
            import mx.rpc.AsyncResponder;
            import mx.rpc.events.FaultEvent;
            protected function kmllayer1_loadHandler(event:LayerEvent):void
                KMLLayer(event.layer).getLegendInfos(new AsyncResponder(kmlLegendResult,kmlLegendFault,null));
                Alert.show(llInfo.legendItemInfos.length.toString());
                for(var lii:int =0; lii < llInfo.legendItemInfos.length; lii++){
                    var lli:LegendItemInfo = llInfo.legendItemInfos[lii] as LegendItemInfo;
                    Alert.show( lli.label);
                trace(evt.message);
    </fx:Script>
    <ags:Map id="myMap"
             openHandCursorVisible="false">
        <esri:KMLLayer name="KML Layer" alpha="1" visible="true"
                       url="http://geocommons.com/overlays/119539.kml"
                       load="kmllayer1_loadHandler(event)"/>
    </ags:Map>
</s:Application>
Sarthak,
  A bit of additional info. When watching the requests in Fiddler there is never any other request made besides the initial request to the utility function on arcgis.com.
SarthakDatt
Robert,
The KML layer internally creates FeatureLayers(feature collection) and hence you do not see any additional legend request. It uses the renderer information on the featureLayer for creating  legend swatches.
The getLegendInfos() on the KML layer is waiting for these featureLayers to load which in this case is not happening before the responder is called. Have you tried other KML layer(s)?
As a work around for now, you could do something like:
    <fx:Script>
        <![CDATA[
            import flash.utils.clearTimeout;
            import flash.utils.setTimeout;
            private var timeOutVar:uint;
                timeOutVar = setTimeout(getKMLLegend, 100, event.layer); // wait for all feature layers to load
            private function  getKMLLegend(layer:KMLLayer):void
                clearTimeout(timeOutVar);
                trace(evt.message);
    </fx:Script>
    <ags:Map id="myMap"
    </ags:Map>
</s:Application>
