Joining graphics into one graphic
1100
05-25-2010 12:56 PM
BrendanLee
I'm trying to union or append graphics into one graphic. Can it be done? Or should I try a different way?
I want to allow the user to draw a polygon on the screen and select the parcels that intersect the polygon. Then I want to take all the parcels and buffer them.
Here's my code:
/* Required with a DrawEnd event.*/
    private function onDrawEnd(event:DrawEvent):void
  var graphic:Graphic = event.graphic;
  // adding graphic to the graphics layer
  myGraphicsLayer.add(graphic);
  var geometryPolygon:Polygon = graphic.geometry as Polygon;
  myMap.centerAt(geometryPolygon.extent.center);
   // select parcels contained or crossed by drawn polygon
  findParcels(graphic);
 private function findParcels(graphic:Graphic):void
  // clear the graphics layer
  myGraphicsLayer.clear();
  // Create query to select parcels that intersect drawn shape
  var parcelQuery : Query = new Query();
  parcelQuery.returnGeometry = true;
  parcelQuery.geometry = graphic.geometry;
  parcelQuery.spatialRelationship = "esriSpatialRelIntersects";
  parcelQuery.outSpatialReference = myMap.spatialReference;
  parcelQueryTask.execute( parcelQuery, new AsyncResponder( onParcelResult, onParcelFault ));
  function onParcelResult( featureSet : FeatureSet, token : Object = null ) : void
   if (featureSet.features.length != 0)
    var unionExtent : Extent;
    var myFirstGraphic : Graphic = featureSet.features[0];
    unionExtent = Polygon(myFirstGraphic.geometry).extent;
    for each (var myGraphic : Graphic in featureSet.features)
                 myGraphic.symbol = (sfs);
                 myGraphicsLayer.add(myGraphic);
                                // THINK I NEED TO ADD SOMETHING HERE TO APPEND ALL GRAPHICS IN FEATURESET INTO ONE GRAPHIC THAT CAN BE USED BY BUFFER FUNCTION.
                    // Adds parcel number and address as tool tip
                    myGraphic.toolTip = "Parcel: " + myGraphic.attributes.PARCEL.toString()
                     + "\nAddress: " + myGraphic.attributes.STRNO + " "
                        + myGraphic.attributes.STRDIR + " "
                        + myGraphic.attributes.STRNAME + " "
                        + myGraphic.attributes.STRTYPE;
                    // Expand extent
     unionExtent = unionExtent.union(Polygon(myGraphic.geometry).extent );
    // Zoom map out a bit
    myMap.extent = unionExtent.expand(6);
   else
    Alert.show("Error selecting parcels");
  function onParcelFault( info : Object, token : Object = null ) : void
   Alert.show( info.toString() );
 private function bufferFeature():void
  var bufferParameters:BufferParameters = new BufferParameters();
        bufferParameters.features = [graphicParcels];
  bufferParameters.distances = [ 500 ];
  bufferParameters.unit = BufferParameters.UNIT_FOOT;
  bufferParameters.bufferSpatialReference = new SpatialReference(32007);
  myGeometryService.addEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler1);
  myGeometryService.buffer(bufferParameters);
  function bufferCompleteHandler1(event:GeometryServiceEvent):void
   for each (var graphic:Graphic in event.graphics)
    graphic.symbol = sfs;
    graphic.toolTip = "Buffered Stuff";
            myGeometryService.removeEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler1);
BrendanLee
I've added the following code:
graphicParcels = myGraphicsLayer.graphicProvider[myGraphicsLayer.numGraphics-1];
But it seems like it doesn't contain all the graphics. If I remove the -1 nothing happens.
I think I'm close...Help!
DasaPaddock
The graphicProvider is an ArrayCollection so you can turn it into an Array like this:
graphicParcels = ArrayCollection(myGraphicsLayer.graphicProvider).toArray();
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/apiref/com/esri/ags/layers/GraphicsLayer.h...
BrendanLee
That worked! Thanks.
