Issues deploying an application
3128
11
08-08-2012 06:39 AM
JohnWall
I am having two issues deploying an application that I have created. First, I am having issues writing to the wwwroot folder even though I have permissions. Do I need to provide Flash Builder 4.6 with permissions?
Second, I have attempted to navigate around the first issue by exporting to one folder and then copying into the wwwroot folder. Still, this does not seem to work. Thus, I am unsure how to get my application properly deployed.
ArcServer and IIS 7.0 are on the same server.
RobertScheitlin__GISP
John,
  So my suggestion is setting up your projects build path much differently (more basic IIS stuff then Flex stuff).
Your Output folder will be:
bin-debug
Your Output folder URL will be:
http://localhost/Flex
Then in IIS your right click on Default Web Site and choose Add Application, for the alias use Flex (or what ever as long as you match the last steps path http://localhost/whatever to this alias), the physical path will be (something like) C:\Flash Builder 4.6\yourappsname\bin-debug or C:\users\{yourusername}\Adobe Flash Builder 4.6\yourappsname\bin-debug.
John,
   Best thing to do is not attempt to write to the wwwroot folder at all, and you accomplish this by setting up a virtual directory that points to a folder on the file system that you have permission to write to with out running Flash Builder as the administrator. Windows 7 does not allow writing to the wwwroot folder unless the application has elevated privileges (meaning you right click the program and choose run as administrator).
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
JohnWall
Hi Robert,
Thanks for your response. I was able to export to the wwwroot folder after checking my my permissions. However, I am still having issues accessing the application. I can access it just fine when I click on the HTML document giving this path: file:///C:/inetpub/wwwroot/flex/gis_test.html
But, then I try to change that to the web address: http://130.83.81.23/flex/gis_test.html
I get the following information returned:
[INDENT]Requested URL: http://130.83.81.23:80/flex/gis_test.html[/INDENT]
[INDENT]Physical Path: C:\Webseiten\Flex\gis_test.html[/INDENT]
Sorry, I am very new to deploying applications using the Flex API.
Thanks again,
John
P.S.
My Output Folder within Flex Builder is 130.83.81.23\flex\bin-debug while my Output folder URL is http://130.83.81.23/flex/
John,
bin-debug
JohnWall
Okay, I changed to bin-debug and http://130.83.81.23/flex (or what it suppose to stay localhost?). I opened up IIS 7 and created a new web page pointing to C:\Users\<name>\Adobe Flash Builder 4.6\gis_test\bin-debug and named that page forschung. But, when I go to  http://130.83.81.23/flex or  http://130.83.81.23/forschung I get a 500 - Internal Server error. What am I missing?
John,
Well it should have been http://localhost/forschung (I don't normally use localhost or an ip address, I just use the machine name).
http://machinename(i.e. gislap134)/forschung
I assume you mean you followed my instructions here:
Then in IIS your right click on Default Web Site and choose Add Application, for the alias use forschung
The physical path is C:\Users\<name>\Adobe Flash Builder 4.6\gis_test\bin-debug
Then in Flash Builder you can click the little green play button on the main toolbar at the top and it should open a browser to:
http://machinename(i.e. gislap134)/forschung/gis_test.html
JohnWall
I now set it to http://loewe/forschung
Now when I press the green play button I view http://loewe/forschung/gis_test.html But, I can only view it locally it seems and even then FireFox gives me errors and does not display the dynamic layers.
John,
   If you are still using the ip address in the main config.xml file for your map services than you need to change those to use the machine name as well, or just go back to using the IP address instead of machine name (it is just my preference to use machine names as they are easier to type than IP addresses).
JohnWall
John,
Thanks! That got it working in FireFox locally, but I cannot access it from other computers. When attempting to access it from other computers I get a 404 Error. The address is http://loewe/forschung/gis_test.html
John,
   Now that is a Windows Firewall issue you have to add an inbound exception. I really don't want to provide guidance here though as this is best handled by your IT Dept.
