Is it possible to display results in a data grid using the compiled version of Flex
1449
07-15-2011 10:37 AM
ZlatkoGrebenar1
Flex Viewer version 2.3.1 (Compiled)
I would like to accomplish two things but I'm not even sure if that's possible using the compiled version. Using the enhanced search widget I would like to search multiple attributes of a layer without using the drop down to select each attribute. Is it possible to have three different attributes next to each other with a textbox where one could type in a value & hit search after all values have been entered?
The second goal would be to display the results in a grid on the bottom of the page after a search has been completed using the e search widget.
See City of Greeley link: http://gis.greeleygov.com/origin/linngrove/
How complex is it to accomplish these two things?
P.S. I have attached an image...:)
Any help is greatly appreciated.
Thank you,
Zlatko
RobertScheitlin__GISP
Zlatko,
   As these needs are very specific to you. You are not going to be able to do this with the compiled version. What you are asking for would require customization of the eSearch Widget and that is why I provide the source code for people to do just that.
Zlatko,
   The fixed datagrid portion of your wish list is now part of the eSearch Widget version 2.3.4. Make sure you read the Enhanced Search Widget Fixed Datagrid Setup.pdf.
ZlatkoGrebenar1
Robert,
I can't thank you enough. I had no problems setting it up, it works great.
You are the best!!
Zlatko
