Change outfields and esri:query layer based on map scale or LOD?
905
07-20-2011 09:48 AM
JohnMcNally
I am using a tiledmapservicelayer to display a map and a querytask to return a geo id and polygon from the service and send the id to a coldfusion function in order fill datagrid/charts with related data.
I was wondering if it was possible to change the query layer and outfields base on what scale or what LOD the user was looking at. essentially I want to change the geographies returned as the user zooms in. I am new to flex/arcgis and I am not sure if I am going about reaching this goal the right way. below is a portion of my code. If someone could point me in the right direction it would be appreciated.
currently this works for one geography layer.
[Bindable] public var querylayer:Number = 4;
[Bindable] public var code:String = "CSDUID";
      private function fault(evt:FaultEvent):void {
                  Alert.show(evt.fault.message);
      private function result(evt:ResultEvent):void {
                  GEODATAGRID.dataProvider = evt.result;
      public function onMapClick(event:MapMouseEvent):void
                query_1.geometry = event.mapPoint;
                queryTask_1.execute(query_1);
      private function onQueryExecuteComplete(event:QueryEvent):void
                myGraphicsLayer.clear();
                graphicsLayer.clear();
                var fset:FeatureSet = event.featureSet;
                for each (var graphic:Graphic in fset.features)
                    graphic.symbol = sfs;
                    graphic.infoWindowRenderer = myInfoWindowRenderer;
                    graphicsLayer.add(graphic);
                    var GEOCODE:Object = new Object();
                    GEOCODE = graphic.attributes
                    getgeodata.geo(GEOCODE);
<mx:RemoteObject
id="getgeodata"
destination="ColdFusion"
showBusyCursor="true"
source="mcnajoh.ARCGIS_MAP.components.getgeodata"
fault="fault(event)" result="result(event)">
<mx:method name="result" result="result(event)">
</mx:method>
</mx:RemoteObject>
<!-- Symbol for Query Result as Polygon -->
<esri:SimpleFillSymbol id="sfs" alpha="0.4" color="0xF8705D">
<esri: outline>
  <esri:SimpleLineSymbol style="solid" color="0x000000" width="2">
  </esri:SimpleLineSymbol>
</esri: outline>
</esri:SimpleFillSymbol>
<esri:QueryTask id="queryTask_1" url="http://c192991:8399/arcgis/rest/services/map/NS_CD-CSD_GDB/MapServer/{querylayer}" executeComplete="onQueryExecuteComplete(event)"/>
<esri:Query id="query_1" returnGeometry="true">
<esri: outFields>
<mx:String>{code}</mx:String>
</esri: outFields>
</esri:Query>
<mx: DataGrid id="GEODATAGRID"
  visible="{queryTask_1.executeLastResult != null}"
  dataProvider="{getgeodata.geo}"
  scroll="true" width="100%" height="100">
<mx:columns>
<mx: DataGridColumn headerText="CSD NAME" dataField="CSDNAME"/>
<mx: DataGridColumn headerText="CSD Type" dataField="CSDTYPE"/>
</mx:columns>
</mx: DataGrid>
<esri:Map id="canmap"
logoVisible="false"
height="100%" width="100%" top="150" backgroundColor="0x467699"
mapClick="onMapClick(event)"
keyboardNavigationEnabled="true">
<esri:lods>
<esri:LOD id="PROV" level="1" resolution="793.7515875031751" scale="3000000.0"/>
<esri:LOD id="PROV_1" level="2" resolution="529.1677250021168" scale="2000000.0"/>
<esri:LOD id="CD" level="3" resolution="264.5838625010584" scale="1000000.0"/>
<esri:LOD id="CD_1" level="4" resolution="132.2919312505292" scale="500000.0"/>
<esri:LOD id="CSD" level="5" resolution="66.1459656252646" scale="250000.0"/>
<esri:LOD id="CSD_2" level="6" resolution="26.458386250105836" scale="100000.0"/>
<esri:LOD id="CSD_3" level="7" resolution="13.229193125052918" scale="50000.0"/>
</esri:lods>
<esri:extent>
<esri:Extent xmin="7691642.342458517" ymin="1216427.9388237474" xmax="9279233.002318736" ymax="1876661.047369435">
   <esri:SpatialReference wkid="3347">
   </esri:SpatialReference>
</esri:Extent>
</esri:extent>
         <esri:ArcGISTiledMapServiceLayer url="http://c192991:8399/arcgis/rest/services/map/NS_CD-CSD_GDB/MapServer">
         </esri:ArcGISTiledMapServiceLayer>
         <esri:GraphicsLayer id="myGraphicsLayer" symbol="{sfs}"/>
         <esri:GraphicsLayer id="graphicsLayer"/>
</esri:Map>
<mx:TraceTarget>
</mx:TraceTarget>
</mx:Application>
Thanks.
RobertScheitlin__GISP
John,
   In you onMapClick function you can check the Map.level and adjust the querylayer and code vars before you execute the queryTask.
JohnMcNally
That did the trick! Thanks very much for your quick response.
