Integrating streetview to my Flex Application urgent.......
13104
44
09-22-2010 12:59 AM
Matildaobaseki
Hi All,
I did integrate Google streetview Wedge by dbechtold to my flex application ran it the first time from my flex builder, it worked, but wont display the second time i ran the flex application.
Also dbechtold  wedge  only displayed one location. I need a code( from the guru's) that when I  used the location wedge in my flex application, which uses esri geocoding Api, it registers the lalng and displays the corresponding location in google streetview panorama.
Any Ideas..................
Matildaobaseki
Hello All,
I would like to say thank you for to all who have replied to this thread especially robert.  My question was resolved....
Thanks to all....
Matilda
ZhujingXia
Hi, Robert,
I used your google street view widget in my flex api application in arcgis server 9.3.1. It worked fine. Thank you.
Is that possible to get rid of the pop up blocker permnatly? It always on my application when I use the widget.
Zhujing
RobertScheitlin__GISP
Zhujing,
   That is controlled in the browser on your machine.
BecaGIS
Hi All,
Still having issues getting this to work in FlexViewer 2.1...
Has anyone managed this and if so, are you able to provide a 2.1 source version?
Regards
LeeAllen
Hi All,
Regards
I suggest you use this widget if you are looking for the source code on google streetview widget.  The help is great.
http://www.arcgis.com/home/item.html?id=dc56d2ab11534d24a5559ea9dc8f5119
BecaGIS
Awesome work on the 2.1 version!
Thanks Lee!
KhaeSaetern
I downloaded the Street View and More �?? Widget for FlexViewer 2.1 from the code gallery and downloaded a trial version of Flash Builder 4. I was able to follow the steps for the FlexViewer part. However, as a newbie to Flash Builder 4, I get the Error #2036 when I do a run test and also on the url itself.  Could this be Flash Build configuration error:
1. Download Flexviewer 2.1 and put flexviewer in Inetpub\wwwroot
2. Download Street View and More �?? Widget for Flexviewer 2.1
3. Download Adobe Flash Builder 4 Trial Version.
4. Create a new Flash Builder, File, New Project
a. Project name: Flexviewer2_1
b. Project location: Folder: W:\wwwroot\Flexviewer2_1
c. Server Technology, Application server Type: None/Other
d. Output folder: default: bin-debug
e. Library Path defaults
i. Main source folder: src
ii. Main application file: index.mxml
iii. Output folder: bin-debug
5. Copy the flexviewer contents containing config.xml, assets, and widgets into Inetpub\wwwroot\Flexviewer2_1\src
6. Copy the folder entitled �??FrStreetView�?� found in the zip file into your widgets folder \Flexviewer2_1\src\widgets and follow the rest of FrStreetView Widget Directions
Thanks!
Kay
andrewj_ca
Matildaobaseki
Hi All,
I' m very pleased my thread(this thread) has helped a lot of developers out there, even after I have officially closed this thread.....
Alot of developers keep coming back to it. This is Awesome.
Matilda
ShawnKraft
Mcnaughty, I am using the StreetViewWidgetv3.zip.  It works.  I got a new map api key and replaced the one in the index.template.html.  Problem is, it still keeps prompting me to get a new map api key.  Weird.  Any ideas?  It might be important to note that I did not alter anything in the index.template.html except replacing the old key with the new one.
