Initial Extent bug in Flex API 2.3?
1032
04-26-2011 12:16 PM
DavidElies
Has anyone gotten the new initial extent to work in 2.3?  I find that when a new map is loaded with a base map from ArcGIS Online, I get the spatial reference from the base map, regardless of what is in the initial extent.  If I set the exent for the map manually (the old way), then it works as expected.
DasaPaddock
The initialExtent property is only used by the zoomToInitialExtent() method. You should still set the extent property as before.
DavidElies
Oh!  Okay.  Sorry about that.  That's good to know!
