InfoWindowRenderer on Click not working over graphic result
818
11-10-2010 03:59 PM
sofoo
I am piecing together pieces of the sample Flex code and I'm having a problem with the InfoWindowRenderer.
I have a search tool that creates a graphic over the result polygon.  The problem is that my click event isn't triggered on the polygon covered by the graphic, so the InfoWindowRenderer does not pop up.
In other words, I can click on all other polygons and my info window pops up, but the graphic is not allowing the underlying feature layer to recognize the click event.  Any help would be greatly appreciated!
DasaPaddock
Try setting mouseEnabled and mouseChildren to false on the blocking Graphic.
Jacbrod
Hello
I have the same problem with InfoWindowRenderer, no result over graphic layer !
Is there a way to use InfoWindowRenderer in this case ?
