Infowindow Renderer is not getting displayed on click
1127
03-23-2012 02:25 AM
MohammedIsmail
hi
Below is the code for infowindowrenderer
am trying display the infowindow on click but i could not get it
can u tell me what could be the reason
<esri:Map id="MyML" x="15" y="17" width="858" height="687" logoVisible="false"
     zoomSliderVisible="true" openHandCursorVisible="false" >
<esri:ArcGISDynamicMapServiceLayer id="la"   url="http://gis-server/ArcGis/rest/services/Bijapur/MapServer" />
<esri:FeatureLayer id="fLayer"
        mode="onDemand"
        outFields="[t_code,t_name]"
        url="http://gis-server/ArcGis/rest/services/Bijapur/MapServer">
  <esri:symbol>
   <esri:SimpleFillSymbol id="fillsym" style="null">
    <esri:SimpleLineSymbol width="3" color="0xFF0000"/>
   </esri:SimpleFillSymbol>
  </esri:symbol>
  <esri:infoWindowRenderer>
   <fx:Component>
    <mx:VBox backgroundColor="0xffffff"
       color="0x444444"
     <mx:Label text="T Code: {data.t_code}"/>
     <mx:Label text="T Name: {data.t_name}"/>
    </mx:VBox>
   </fx:Component>
  </esri:infoWindowRenderer>
</esri:FeatureLayer>
</esri:Map>
Thanks & Regards
Be happy and keep smiling
ISMAIL
JinnanZhang
Hi ISMAIL,
I think the problem is associated with the URL of your FeatureLayer.
The correct URL should look like this: url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer/0" , that means you have to put an URL for an exact layer instead of put URL for entire map service.
I don't know which layer you should use but you can try to modify your URL to someting like:
"http://gis-server/ArcGis/rest/services/Bijapur/MapServer/0" or "http://gis-server/ArcGis/rest/services/Bijapur/MapServer/1"
See if that works.
Best,
Jinnan Zhang
MohammedIsmail
hi
i tried but its not working how can i do this now
pls if u can help me to solve then it will be great
thanks
ISmail
MohammedIsmail
hi
its working with vector files but it is not working with rasters
what could be the problem
Thanks
Ismail
