InfoPopupWidget not popolate at first click
779
08-05-2011 12:23 AM
MicheleFocareta
i am the prloben when i first-click  on item generate infopopupwindows empty if i click another item the infopopup is correctly popolate...
if I use ESRI API 2.3.1 and SDK 4.1 there is the problem, but if i use ESRI API 2.2 i do not have problem.
The probability part of error code is:
var infoWindowRenderer:ClassFactory = new ClassFactory();
var infoWindowContentisplayObject;
if (event.currentTarget != null)
var recreate:Boolean = true;
var graphic:Graphic = Graphic(event.currentTarget);
if (map.infoWindow.content != null) {
recreate = !((graphic.attributes.type == SocialMediaType.Flickr && (map.infoWindow.content is Flickr_InfoWindowRenderer)) ||(graphic.attributes.type == SocialMediaType.YouTube && (map.infoWindow.content is YouTube_InfoWindowRenderer)));
if (recreate) {
if (graphic.attributes.type == SocialMediaType.Flickr) {
infoWindowRenderer = new ClassFactory(Flickr_InfoWindowRenderer);
else if (graphic.attributes.type == SocialMediaType.YouTube) {
infoWindowRenderer = new ClassFactory(YouTube_InfoWindowRenderer);
infoWindowContent = infoWindowRenderer.newInstance();
map.infoWindow.content = infoWindowContent as UIComponent;
map.infoWindow.closeButtonVisible = true;
map.infoWindow.data = graphic.attributes;
map.infoWindow.label = graphic.attributes.title;
map.infoWindow.show(map.toMapFromStage(event.stageX, event.stageY));
is there a solution?  is a bug af API 2.3.1 or not?
MicheleFocareta
Hello, today I found a solution to my problem!!
In my mxml file i created a <fx:Component  className="Flickr_InfoWindowRenderer"> :
     <mx:VBox verticalGap="0" autoLayout="true">
  <fx:Script>
  <![CDATA[
   protected function ShowImage(event:MouseEvent):void
    if (event.currentTarget is Image) {
  var imageUrl:String = (event.currentTarget as Image).source as String;
  var urlRequest:URLRequest = new URLRequest(imageUrl);
         navigateToURL(urlRequest, "_blank");
  </fx:Script>
<mx:Image source="{data.image}" click="ShowImage(event)" maintainAspectRatio="true" width="240" height="160" />
<mx:Label text="Autore: {data.owner}" paddingBottom="0" paddingTop="0" horizontalCenter="0" />
</mx:VBox>
</fx:Component>
When i complete my search i add each item to graphic layer:
for each (var flickr:FlickrItem in event.Results) {
    var x:Number = Number(flickr.point.x.toPrecision(8)) ;
    var y:Number = Number(flickr.point.y.toPrecision(8));
   myArrCoord.addItem({coordX:x,coordY:y});
var mapPoint:MapPoint = new MapPoint(x, y, new SpatialReference(102100));
       var newMapPoint:MapPoint =  WebMercatorUtil.geographicToWebMercator(mapPoint) as MapPoint;
graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(mapPoint));
graphic.attributes = {"type": "Flickr", "title": flickr.title, "owner": flickr.ownerName, "image": flickr.imageUrl, "datetaken": flickr.dateTaken, "description":flickr.description};
graphic.addEventListener(MouseEvent.CLICK, SocialMediaGraphic_ClickHandler);
flickrGraphicsGeowalker.add(graphic);
When i click to item on the map infowindows is empty!!
SOLUTION
1) Add id to fx:Component
<fx:Component id="Flickr" className="Flickr_InfoWindowRenderer">
2)Assigne ad graphic the component id
graphic.infoWindowRenderer = Flickr;
Michele
