Info Window in Sample Flex Viewer 2.1 Question
1521
10-25-2010 01:41 PM
EmilyLaMunyon
Hello,
I am using the Search widget in the Sample Flex Viewer 2.1, and would like to add more information/attributes to the info window that appears when a feature is found. Currently, it is only displaying one attribute. How would I go about this?
Thanks!
JoshTanner
Edit the SearchWidget.xml file.
<configuration>
<layers>
<layer>
<name>Parcels</name>
<url>http://173.15.61.163/ArcGIS/rest/services/Website/MapServer/4</url>
<expression>macongis.SDE.Parcels.PIN = '[value]'</expression>
<textsearchlabel>Search by Parcel ID [ Example: 12-15-284-010 ]:</textsearchlabel>
<graphicalsearchlabel>Use one of the graphical search tools to select parcels</graphicalsearchlabel>
<titlefield>Parcel</titlefield>
<linkfield></linkfield>
<fields all="false">
<field name="macongis.SDE.Parcels.PIN" alias="PIN"/>
<field name="macongis.SDE.ParcelDataccWeb.PrimaryName" alias="Owner"/>
<field name="macongis.SDE.ParcelDataccWeb.SiteAddress" alias="Address"/>
</fields> </layer>
</layers>
<zoomscale>5000</zoomscale>
<info>widgets/InfoTemplates/InfoPopupWidget.swf</info>
</configuration>
The part in red is my fields that show up. You just need to add in the fields that you want to see.
EmilyLaMunyon
Thanks Josh. I have tried that and still no luck. Do I need to recompile the swf?
EmilyLaMunyon
Nevermind..figured it out, thanks!
