Info Pop up Window Trouble
2070
6
11-02-2010 12:01 PM
DerekTokarz1
I keep geting the error message,
"[IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]
http response status: 404
Fault Code: Server.Error.Request
Fault Info: HTTP request error
Fault Details: Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://rtams.org/flexviewer/widgets/InfoTemplates/CTASTATIONS.xml"
I have my files in SDE here is what my xml file looks like
<layer label="CTA Stations" type="feature" visible="true"
info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
infoconfig="widgets/InfoTemplates/CTASTATIONS.xml"
url="http://rtamsp2.ai.uic.edu:8399/arcgis/rest/services/sdeLayers/MapServer/0"/>
Any ideas?
I added the filed names to the infotemplates. Feature Access is also turned on in ServerManager.
RobertScheitlin__GISP
Derek,
   Are you able to put http://rtams.org/flexviewer/widgets/InfoTemplates/CTASTATIONS.xml in your browser address bar and actually see the file?
DerekTokarz1
No I am not able to see it. I can see http://rtamsp2.ai.uic.edu:8399/arcgis/rest/services/sdeLayers/MapServer/0
Am I supposed to be able to .xml?
Derek,
   Then that is definitely the source of your error. You have to figure out what is wrong with that url...
DerekTokarz1
Why does it have to be a URL if it is directed to an .xml file located in the widgets folder?
Thanks for the help by the way.
Derek,
  The error that you are getting has to do with the file not being there. Flex is 100% case sensitive so could that be your issue in the path to your xml file?
PetrTrefil
Any ideas?
in config.xml Try to write URL without specification of number of layer in rest service
url="http://rtamsp2.ai.uic.edu:8399/arcgis/rest/services/sdeLayers/MapServer"/>
