Include Overview Map in Snapshot Image
11151
36
06-03-2010 09:19 AM
StuartBlumberg
I am using a "snapshot" button in order to export the current extent as a JPEG.  How would I include an overview map in a corner of the JPEG snapshot showing where in the city the snapshot is showing?  I am using the Flex Sample Viewer.  I am using the following code to create the snapshot:
private function clickHandler() : void
   var map:Map = SiteContainer.getInstance().controller.map;
   const decoder: JPEGEncoder = new JPEGEncoder();
   map.logoVisible=false;
   map.scaleBarVisible=true;
   map.zoomSliderVisible = false;
   SiteContainer.getInstance().mapManager.control.visible = false;
               //get the current background color of the map
               var currentMapColor:Object = map.getStyle("backgroundColor");
               //set the background color to white
               map.setStyle("backgroundColor", "#CCCCCC");
               //validate the changes
               map.validateNow();
   const imageSnapshot:ImageSnapshot =
  ImageSnapshot.captureImage(map);
   map.logoVisible=true;
   map.zoomSliderVisible = true;
   map.setStyle("backgroundColor", currentMapColor);
               map.validateNow();
   const fileReference:FileReference = new
  FileReference();
   fileReference.save
  (imageSnapshot.data,"map.jpg");
RobertScheitlin__GISP
Stuart,
   OK I think I got it worked out for dynamic and static this time.
<?xml version="1.0" encoding="utf-8"?>
// Copyright © 2008 - 2009 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/FlexViewer/License.txt
<BaseWidget xmlns    ="com.esri.solutions.flexviewer.*"
   xmlns:esri   ="http://www.esri.com/2008/ags"
   xmlns:mx   ="http://www.adobe.com/2006/mxml"
   xmlns:mxeffects  ="com.adobe.ac.mxeffects.*"
   xmlns:widgets  ="com.esri.solutions.flexviewer.widgets.*"
   x     ="600"
   y     ="300"
   widgetConfigLoaded ="init()">
 <mx:Script>
  <![CDATA[
   import com.esri.ags.events.LayerEvent;
   import mx.collections.ArrayCollection;
   import com.esri.ags.utils.WebMercatorUtil;
   import com.esri.ags.virtualearth.VETiledLayer;
   import com.esri.ags.events.ExtentEvent;
   import com.esri.ags.geometry.Extent;
   import com.esri.ags.geometry.MapPoint;
   import com.esri.ags.Graphic;
   import com.esri.ags.layers.GraphicsLayer;
   import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
   import com.esri.ags.layers.ArcGISTiledMapServiceLayer;
   import com.esri.ags.symbol.SimpleFillSymbol;
   import com.esri.ags.symbol.SimpleLineSymbol;
   import com.esri.ags.Map;
   import flash.events.MouseEvent;
   import mx.controls.Alert;
   import mx.graphics.ImageSnapshot;
   private var overviewMode:String;
   private var graphicLineSym:SimpleLineSymbol = new SimpleLineSymbol("solid", 0xFF0000, 0.8, 3);
   private var graphicPolySym:SimpleFillSymbol = new SimpleFillSymbol(null, 0xFF0000, 0.01, graphicLineSym);
   private var graphicsLayer:GraphicsLayer;
   private var ovGraphic:Graphic;
   private var xOff:Number;
      private var yOff:Number;
   private function init():void
    if (configXML)
     var type:String = configXML.mapservice.@type;
     var url:String = configXML.mapservice;
     var style:String = configXML.mapservice.@style;
     var label:String = configXML.mapservice.@label;
     overviewMode = configXML.mapservice.@mode;
     switch (type.toLowerCase())
      case "tiled":
       var tiledlayer:ArcGISTiledMapServiceLayer = new ArcGISTiledMapServiceLayer(url);
       tiledlayer.alpha = alpha;
       if (overviewMode == "dynamic")
        tiledlayer.addEventListener(LayerEvent.TILES_UPDATED,updateOvExtent);
       ovMap.addLayer(tiledlayer);
       break;
      case "dynamic":
       var dynlayer:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(url);
       dynlayer.alpha = alpha;
        dynlayer.addEventListener(Event.COMPLETE,updateOvExtent);
       ovMap.addLayer(dynlayer);
       break;
      case "virtualearth":
       var veTiledLayer:VETiledLayer =  new VETiledLayer();
       veTiledLayer.id = label;
        veTiledLayer.tokenURL = url;
        veTiledLayer.environment = "production";
        veTiledLayer.visible = true;
        veTiledLayer.alpha = alpha;
        veTiledLayer.mapStyle = style;
        veTiledLayer.name = label;
        ovMap.addLayer(veTiledLayer);
        break;
     graphicsLayer = new GraphicsLayer();
     graphicsLayer.symbol = graphicPolySym;
     ovMap.addLayer(graphicsLayer);
     ovGraphic = new Graphic();
     ovGraphic.geometry = map.extent;
     ovGraphic.addEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler);
     ovGraphic.addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
     graphicsLayer.add(ovGraphic);
     map.addEventListener(ExtentEvent.EXTENT_CHANGE, setOverviewExtent);
     ovGraphic.addEventListener(Event.CHANGE,updateOvExtent);
     updateOverviewExtent();
     setTimeout(updateOverviewExtent, 4000);
   private function setOverviewExtent(event:ExtentEvent):void
    if (overviewMode == "dynamic"){
     ovMap.extent = map.extent.expand(3);
    try{
     var ac:ArrayCollection = new ArrayCollection([]);
     var bmpDat:BitmapData = ImageSnapshot.captureBitmapData(ovMap);
     ac.addItem(bmpDat);
     addSharedData("ovMap",ac);
    catch(err:Error){
    AddOVMap();
   private function updateOverviewExtent():void
    try{
     ac.addItem(bmpDat);
    catch(err:Error){
    AddOVMap();
   private function updateOvExtent(Evt:Event):void
    callLater(AddOVMap,null);
   private function AddOVMap():void
    try{
     ac.addItem(bmpDat);
    catch(err:Error){
   private function mouseDownHandler(event:MouseEvent):void
       var ext:Extent = ovGraphic.geometry as Extent;
       var mPt:MapPoint = ovMap.toMapFromStage(event.stageX, event.stageY);
       xOff = ext.center.x - mPt.x;
          yOff = ext.center.y - mPt.y;
          ovGraphic.addEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler);
   private function mouseMoveHandler(event:MouseEvent):void
       var tempX:Number = mPt.x + xOff;
    var tempY:Number = mPt.y + yOff;
    var newext:Extent = new Extent(tempX - ext.width / 2, tempY - ext.height/ 2, tempX + ext.width / 2, tempY + ext.height / 2);
       ovGraphic.geometry = newext;
       if (!event.buttonDown)
        ovGraphic.removeEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler);
      private function mouseUpHandler(event:MouseEvent):void
       map.extent = ovGraphic.geometry as Extent;
      private function widgetOpenedHandler(event:Event):void
    setTimeout(updateOverviewExtent, 1000);
      private function widgetClosedHandler(event:Event):void
    map.removeEventListener(ExtentEvent.EXTENT_CHANGE, setOverviewExtent);
   private function widgetMinimizedHandler(event:Event):void
 </mx:Script>
 <WidgetTemplate id="wTemplate" widgetClosed="widgetClosedHandler(event)" widgetOpened="widgetOpenedHandler(event)" widgetMinimized="widgetMinimizedHandler(event)">
  <esri:Map id       ="ovMap"
     width      ="100%"
     height      ="100%"
     panArrowsVisible   ="false"
     zoomSliderVisible   ="false"
     logoVisible     ="false"
     scaleBarVisible    ="false"
     panEnabled     ="false"
     clickRecenterEnabled  ="false"
     doubleClickZoomEnabled  ="false"
      keyboardNavigationEnabled ="false"
      rubberbandZoomEnabled  ="false"
     scrollWheelZoomEnabled  ="false">
  </esri:Map>
 </WidgetTemplate>
</BaseWidget>
StuartBlumberg
Works beautifully now, you are a genius!  City workers here will be pleased.  Thank you!
KarlWilson
I'd like to be able to have this "snapshot" functionality in a widget for SFV 2.1 so that I can save a map as a JPG. Does something like this already exist?
If not, what would be the best way to go about creating this? Some tips for a beginner here would be much appreciated!
Thanks.
ErwanCaradec
Is it possible to make a snapshot of a specified extent of the map without zooming ?
Erwan
Erwan,
   It would take you using the exportMapImage method on the map services that supported it and merging them together in flex using bitmap methods (to the best of my knowledge).
ErwanCaradec
Thanks Robert ! You showed me the right way using the bitmap methods.
But instead of using captureImage method of ImageSnapshot, i directly use captureBitmapData, wich return a BitmapData. Then I can copy only pixels corresponding to the rectangle of my selected extent.
Finally, i could create a SnapshotWidget wich can save selected part of the map (with a preview) or the entire map in formart jpg or png.
http://erwan.caradec.pagesperso-orange.fr/flexViewer/index.html?config=configs/tests/config.xml
Regards
Erwan
KarlWilson
Thanks Robert!
Erwan, your widget is very neat. Are you planning to add that to the code gallery by any chance?
Cheers.
philippschnetzer
Robert,
Great ExportMapImage widget!  Is it possible to allow certain widgets to be able to be included in the jpg as well?  Namely your dynamic legend should be included in an exported image of the map.  Would be great to know where to add this in the code...
Thanks!
Phillip,
   There is a public function (exportImage) that can be called on the DynamicLegendWidget that will return a BitmapImage. But you will still have to work with flex bitmap objects to place and combine the returned BitmapImage with the one that is returned for the map. Sorry I don't have time to give a code example right now.
