Include Overview Map in Snapshot Image
11106
36
06-03-2010 09:19 AM
StuartBlumberg
I am using a "snapshot" button in order to export the current extent as a JPEG.  How would I include an overview map in a corner of the JPEG snapshot showing where in the city the snapshot is showing?  I am using the Flex Sample Viewer.  I am using the following code to create the snapshot:
private function clickHandler() : void
   var map:Map = SiteContainer.getInstance().controller.map;
   const decoder: JPEGEncoder = new JPEGEncoder();
   map.logoVisible=false;
   map.scaleBarVisible=true;
   map.zoomSliderVisible = false;
   SiteContainer.getInstance().mapManager.control.visible = false;
               //get the current background color of the map
               var currentMapColor:Object = map.getStyle("backgroundColor");
               //set the background color to white
               map.setStyle("backgroundColor", "#CCCCCC");
               //validate the changes
               map.validateNow();
   const imageSnapshot:ImageSnapshot =
  ImageSnapshot.captureImage(map);
   map.logoVisible=true;
   map.zoomSliderVisible = true;
   map.setStyle("backgroundColor", currentMapColor);
               map.validateNow();
   const fileReference:FileReference = new
  FileReference();
   fileReference.save
  (imageSnapshot.data,"map.jpg");
RobertScheitlin__GISP
Stuart,
   You need to debug and put a breakpoint on this line
if (dataTable.containsKey("ovMap"))
to see if you are getting into this if statement.
Stuart,
  Try adding this line to the very end of the init function in the OverviewWidget.mxml
setTimeout(updateOverviewExtent, 4000);
StuartBlumberg
I actually don't think I am running the debug version of flashplayer, it says, "Flex Builder cannot locate the required debugger version of Flash Player.  You might need to install the debugger version of Flash Player 9 or reinstall Flex Builder."
I tried adding that line at the end of the init function but still nothing happened.
Stuart,
   Pan your map around and watch to see that the overview map is done redrawing and try exporting again.
StuartBlumberg
Robert,
I tried panning the map around and waiting for the overview map to redraw but still nothing.  I have attached two images: a screenshot of my application before I export the image; the other is the exported image.  I dont know if it makes a difference but I am using version 1.3 of the API library.
Stuart,
   You need to get the debugger version of flash player so you can put a break point in the code as I mention in the previous post. I don't have a clue what is wrong on your end as I just took the two files and added it to another SFV project and it ran perfectly again.
Stuart,
   Replace this code in the OverviewMapWidget.mxml
private function setOverviewExtent(event:ExtentEvent):void
    ovGraphic.geometry = map.extent;
    if (overviewMode == "dynamic"){
     ovMap.extent = map.extent.expand(3);
    try{
     var ac:ArrayCollection = new ArrayCollection([]);
     var bmpDat:BitmapData = ImageSnapshot.captureBitmapData(ovMap);
     ac.addItem(bmpDat);
     addSharedData("ovMap",ac);
    catch(err:Error){
   private function updateOverviewExtent():void
    try{
     ac.addItem(bmpDat);
    catch(err:Error){
StuartBlumberg
Robert,
I have added the new code and the overview map now shows up in the bottom right corner.  However, the extent rectangle is larger than the area of the actual map.  I have attached the exported image.   Thanks.
Stuart,
   Is that not the exact same image that is in the overviewmapwidget? Because it should be exactly the same.
StuartBlumberg
Robert,
It is the same image, however the extent rectangle is wrong, it is bigger than the area it represents in the map.  Also, unless I use the "+" or "-" on the zoom slider to zoom in/out I get the image shown in the attachement below.  If I zoom in with zoom tool or if I click inside the zoom slider to zoom into a specific scale, it shows the image as shown in the attachement.  I can only get the image in the attachement in the previous post if I use the "+" or "-" buttons.  Thanks.
