ImageSnashop size 800 x 600
1941
04-12-2010 08:52 AM
AlexanderMena
How I can get ImageSnapshot of size 800 x 600 ?
I have the next code and I don't works.
ImageSnapshot.MAX_BITMAP_DIMENSION = 800;
var imageSnapshot:ImageSnapshot = ImageSnapshot.captureImage(map,0,jpgEnc);
imageSnapshot = new ImageSnapshot(800,600,imageSnapshot.data);
thank a lot your help.
Alexander Mena.
PrashanthSukumaran
Hi Alexander,
Are you trying to scale it?
Thanks
Prashanth Sukumaran
AlexanderMena
Yes I do. I trying of get a image with size 800 x 600 pixels. The ImageSnashop class  returns a image with size 1020 x 567 pixels.
PrashanthSukumaran
Hi Alexander,
Looking at the ImageSnapshot.as code i think the solution provide below should work.
The captureImage is basically trying to scale the image based on the screen DPI.   Looks like Flash is returning 72 dpi always.  Since you are doing this
The second parameter Zero means zero dpi the scale is 1 always for you.  ie.,
Matrix(1,0,0,1).  So ImageSnapshot.captureimage it is returning the same size as the displayobject.
Doing this will not have any effect.
So in your case it would be  Matrix(1020/800, 0, 0, 567/600).  ie., Matrix(1.275, 0, 0, 0.945).  Since the scale is not the same, i don't think you will be able to use the captureImage.
Instead you should try to use  ImageSnapshot.captureBitmapData where you will pass your custom Matrix yourself.
Is this too much code.....
                var width:int;
                var height:int;
                var bytes:ByteArray;
                var matrix:Matrix = new Matrix(1.275, 0, 0, 0.945)
                var data:BitmapData = ImageSnapshot.captureBitmapData(map, matrix);
                var bitmap:Bitmap = new Bitmap(data);
                width = bitmap.width;
                height = bitmap.height;
                bytes = encoder.encode(data);  // encoder is the JPEGEncoder you want to use.  I think by default the encoding is done in PNG.
                This bytes can be saved to the backend or you could create another imagesnapshot object to encode the images as  base64.
Thanks
Prashanth Sukumaran
NOTE:  Check the ImageSnapshot.as code that comes with Flex SDK.  It is really easy to understand what i am saying.
If you have installed 3.5 sdk you will find it in this folder (sdks\3.5.0\frameworks\projects\framework\src\mx\graphics\ImageSnaopshot.as)
AlexanderMena
Thank Prashanth, this is work fine. Do not use it because the image obtained is of low quality.
Alexander Mena.
PrashanthSukumaran
Alexander Mena.
Try PNG, you should see a good quality output. JPEG is lossy compression and would not be good.
