Identify widget wont show hyperlink
8104
40
06-09-2010 01:37 PM
ShawnKraft
I have a virtual directory set up to where my plats are.  They are in .tif format but I do have one in .pdf format to use to test this widget.
                                <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel>
  <pointlabel>Identify</pointlabel>
  <clearlabel>Clear</clearlabel>
  <loadinglabel>Loading...</loadinglabel>
  <selectionlabel>Features Identified:</selectionlabel>
</labels>
<layers>
  <layer>
   <name>Lot</name>
   <linkfield>PLATLINK</linkfield>
  </layer>
  <layer>
   <name></name>
   <linkfield></linkfield>
  </layer>
</layers>
</configuration>
Not sure why this isn't working.  I modified the identifywidget.xml, do I need to modify anything else to get this to work? Might be easier to just explain what to do and I will do it per the instructions and see if I missed anything.
ShawnKraft
So when is ESRI gonna hire you for helping all the people you have helped lol.
ShawnKraft
Okay I am a bonehead.  I used your myIdentify_v1.2.02.  It worked.  All I had to do thru my iterations was remove and re-add the IdentifyWidget to the modules each time I did an iteration to test it.
ShawnKraft
Actually it was the myIdentify v1.3 that worked.
RobertScheitlin__GISP
Shawn,
   Good to hear it I was running out of suggestions...
ShawnKraft
LOL.  Widget works great.  Thanks Robert
NatashaManzuiga
Shawn, can u send here your identifywidget.mxml and identifywidget.xml?
I have the same problem :S
Naty
ShawnKraft
Yes I can send it to you.
ShawnKraft
Here they are.
RuthCostley
I have the same problem as stated above where the identify tool in the flexviewer folder returns Identify operation not supported on this service. What were the steps to fixing the problem?
PeterFerretti
Shawn,
It seems the zip file you posted is corrupt (Identify Tool v1.3). Could you please repost? Thanks in advance.
