Identify Widget Shrinking/Disappearing
946
03-10-2011 11:08 AM
DebraFredrick
I'm suddenly noticing a problem with the Identify Widget.
Users will be going around and using the Identify widget and everything will be fine, then all the sudden the widget will resize itself and sometimes vanish completely.  Has anyone else experienced this with widgets and know maybe what might be causing it.
It can be very inconsistent so its hard to figure out why its happening?
Thanks in advance
RobertScheitlin__GISP
Debra,
   I have never seen the shrinking widget issue  but there is a known issue in the viewer that is very sporadic, with widgets moving off the stage by them selves. The Viewer team is aware of the issue.
