Identify on different projection tile layer
1258
08-18-2010 04:07 AM
ManuelFrias
Hello,
All layers in my service are in spatial reference 3035, including the base map tile layer. The identify tool works fine. If I try the World_Street_Map from arcgisonline the identify doesn't work. It doesn't return anything.
I thought it might be a problem with the projection (World_Street_Map is in 102100) but isn't it so that my dynamic layers get reprojected on the fly? Is there anything I am missing?
Manolo
RobertScheitlin__GISP
Manolo,
   If you go to the REST service page for that map service
http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer
You will notice that it does not support identify
Supported Operations:   Export Map   Generate KML
Ones that support identify will have
Supported Operations:   Export Map   Identify   Generate KML
ManuelFrias
Hi Robert,
sorry, I didn't explain myself clearly. I don't want to identify the World_Street_Map I want to identify my own dynamic layers.
When I have my background tile layers I can identify my dynamic layers. They are both in the same projection. When I switch to World_Street_Map I can not.
The first thing it came to my mind is that the spatial reference is different.
Manolo
Manolo,
   I would agree that it is a spatial reference issue. Have you tried to set the IdentifyParameters spatial reference?
ManuelFrias
Thanks a lot Robert!
setting the spatial reference did it!
Manolo
