I am having a problem with the Dynamic Legend.
1101
03-25-2012 06:19 PM
DeepLakhanpal
As per the functionality it works fine with our network, but when I try to access the application outside of our network its display HTML output in Legend Window.
Though internal network Dynamic legend request generate legend images within proxyoutput directory. But when I access the application outside out network, map request gets successful and a temp image generate in proxyoutput, but not legend images.
I have configured CrossDomain.xml please find below the contents.
<?xml version="1.0"?><!DOCTYPE cross-domain-policySYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
<site-control permitted-cross-domain-policies="all"/>
<allow-access-from domain="*" />
<allow-access-from domain="*.esri.com" />
<allow-access-from domain="*.arcgisonline.com" />
<allow-access-from domain="*" to-ports="*" />
<allow-http-request-headers-from domain="*" headers="*"/>
</cross-domain-policy>
Thanks & Regards
Deep
DeepLakhanpal
I have this issue in our environment.
User request is been full fill through ISA proxy server. As per the current configuration Flex portal request redirect to port 80 for ArcGIS Server (Which is standard) but for Portal which is access through a tab in a sharepoint portal, request is redirected through a different port. Does these ports need to be same (same as ArcGIS Server standard port 80).
Thanks & Regards
Deep
DeepLakhanpal
Hi Everyone,
Can some explain about the below mention error which appears in log of Dynamic legend web service. I believe the issue can be due to ISA proxy server setting as this same service works well when we try t access the portal within TSL network.
#Software: Microsoft Internet Information Services 6.0
#Version: 1.0
#Date: 2012-04-04 09:29:59
#Fields: date time s-sitename s-computername s-ip cs-method cs-uri-stem cs-uri-query s-port cs-username c-ip cs-version cs(User-Agent) cs(Cookie) cs(Referer) cs-host sc-status sc-substatus sc-win32-status sc-bytes cs-bytes time-taken
2012-04-04 09:29:58 W3SVC1996500661 <SERVER NAME> 10.1.12.101 POST /DynamicLegend/restLegend.asmx - 8083 - 10.1.18.10 HTTP/1.1 Mozilla/4.0+(compatible;+MSIE+6.0;+Windows+NT+5.1;+SV1;+.NET+CLR+1.1.4322;+.NET+CLR+2.0.50727;+.NET+CLR+3.0.4506.2152;+.NET+CLR+3.5.30729) - http://crnappstst.servicesfields.com/gis/flexapps/ast_cntr/index.swf crnappstst.servicesfields.com 200 0 0 16835 1148 3109
