I,AM BEGINNER IN FELX API USING ARCGIS SERVER 9.3.1
2656
11
06-04-2010 12:11 AM
mohamedabouzaid
HELLO ALL ,
ITS MY FIRST WEB APP USING FLEX API
WOULD ANY ONE PLEASE TO GIVE ME THE CODE FOR PUTTING MY OWN DATA LIKE SHAPEFILES_GEODATABASE
IN MY APPLICATION.
THANKS ALOT .
RobertScheitlin__GISP
mohamedabouzaid
MANY THANKS MR ROBERT FOR YOUR INTEREST
BUT WOULD YOU PLS TO GIVE ME AN EXAMPLE SHOWING HOW CAN I ADD MY DATA.
THAT IS THE FIRST TIME TO SEND A TOPIC IN ESRI FORUMS AND I AM A NEW IN BUILDING WITH FLEX AND
ABSOLUTELY BEGINNER IN PROGRAMMING .
THANKS A LOT AGAIN.
Mohamed,
   All you need to do to add your own data is go to your REST Services directory http://localhost/ArcGIS/rest/services/ and see a listing a map services that you have available and click on one and copy the url from the address bar and paste that into on of the samples.
Here is one of ESRI's map services:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...
Here is an example of what one on your server would look like:
http://localhost/ArcGIS/rest/services/mydata/MapServer
So using the most simple sample from the link I provided you the code example would look something like this
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
    xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:esri="http://www.esri.com/2008/ags"
    pageTitle="Example - ArcGIS API for Flex connecting to a dynamic AGS service">
    <esri:Map>
        <esri:ArcGISDynamicMapServiceLayer
            url="http://localhost/ArcGIS/rest/services/myData/MapServer"/>
    </esri:Map>
</mx:Application>
__1
THANKS A LOT AGAIN.
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/samples/index.html
You can find lots of samples here.
mohamedabouzaid
many thanks for all . i will try to get a good result in my first application using flex.
now i have a concept.
bye
mohamedabouzaid
this my code to publish my own mxd but it wasnot worked
would any one please to handle my code .i use arcgisservre9.3.1 and flexbuilder 3
here is my code
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:esri="http://www.esri.com/2008/ags">
<esri:Map>
            url="http://orcl/ArcGIS/rest/services/NEW_RIYADH/MapServer"/>
    </esri:Map>
</mx:Application>
GiosiaPoma
Hi mohamed,
the arcgis server and the webserver with the flash application is on the same server? If not you must add the crossdomain.xml on the arcgis server web root.
Regards
mohamedabouzaid
MANY THANKS BUT I ,VE FAILED TO GET A RESULT. WOULD YOU MIND PLEASE  TO GIVE ME SOME CODE ABOUT THIS TOPIC?.
REGARDS
Mohamed,
    You really need to start doing some reading. Code snippets will do little good for a manager if you don't understand what is happening in the code. Start looking here http://resources.esri.com/help/9.3/arcgisserver/apis/flex/help/content/getting_started.htm and then read this about the crossdomain.xml http://resources.esri.com/help/9.3/arcgisserver/apis/flex/help/content/deploy_application.htm
