Hyper Link to an MHT file
3250
07-12-2012 12:25 PM
DavidBrooks3
I am attempting to open MHT files from a Flex Viewer 3.0 hyper link.  I have links working that have "http://" urls but have yet to get the below examples to work as a link in the popup XML.  I have dropped an HTM file with the links in the flex application folder and the links open the MHT files fine.  Both links below work fine when the urls are pasted into a browser but the flex links don't even blink.
<A href="mhtml:file://\\000.000.000.0\operations\City.mht!City_files/frame.htm">MHT test 1</a>
<A href="file://000.000.000.0/operations/City.mht">MHT test 2</a>
Any help and direction would be appreciated.
RhettZufelt
MVP Notable Contributor
have you tried using a virtual folder on your server that points to your operations folder?
This will normally solve that type of issues as you could now use a an actual URL to access the same path like so:
<A href="http://000.000.000.0/operations/City.mht">MHT test 2</a>
R_
RhettZufelt
R_
DavidBrooks3
That did the trick.
Thank you!
