How to stop scaling PictureMarkerSymbol when zooming?
1266
06-21-2011 11:33 PM
FewkesFewkes
Hey,
I have ArcGISTiledMapServiceLayer and GraphicLayer on it with some PictureMarkerSymbols. How to stop scaling those symbols during the zooming of the map? After zoom in they back to orginal size.
Regards
MLowry
Did you trying setting a reference scale in the mxd properties and then publishing to msd?
YungKaiChin
Well ... The application zoom in before it receives data or it can re-draw the graphic symbols
What you can do to solve the problem:
1. Get a faster internet connection (client PC)
2. Get a good graphic card (client PC)
3. Get a faster processor (client PC)
4. If you have your own services, do 1, 3 to your server.
5. All the above
What you can not help:
1. Speed of ESRI's services or third part services
However, you also can use the zoomStart event of the map to make symbol invisible and make it visible again once zoomEnd
ShaunWeston
I have the same problem as this I believe...
I have a DrawTool that adds points to a graphics layer (these points are actual images) and when the user zooms in and out the point re-scales itself. Is there anyway to fix the zoom of these images, so that when the user zooms in and out, the image stays the same size?
