how to realize a zoom function in the droplist?
4577
25
01-05-2011 05:26 PM
GeorgiannaStrode
I edited a bookmark widget, replacing the bookmark list with a droplist successfully. The droplist is populated with data from a mapserver(the data from a layer attribute of the mapserver)
Whenever the user makes a selection in the droplist, I wanna it to zoom to the selected record. I have not realized the zoom function yet. If anyone has experience in this function or knows how to do it, please let me know. I would appreciate your help
My codes are as below.Note that the change="showBookmark(event)" does not work. Thats what I think I might be doing wrong.
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx"
xmlns:viewer="com.esri.viewer.*"
xmlns:Bookmark="widgets.QBookmark.*"
x="600" y="300"
layout="absolute"
widgetConfigLoaded="init()" xmlns:esri="http://www.esri.com/2008/ags">
<fx:Script>
<![CDATA[
import com.esri.ags.FeatureSet;
import com.esri.ags.utils.GraphicUtil;
import com.esri.ags.geometry.Extent;
import mx.collections.ArrayList;
import mx.controls.Alert;
import mx.rpc.AsyncResponder;
import mx.events.EffectEvent;
import spark.components.supportClasses.ItemRenderer;
import spark.core.NavigationUnit;
private const BOOKMARKS:String = "bookmarks";
private const ICON_URL:String = "assets/images/";
//labels
private var bookmarksLabel:String;
[Bindable]
//query info
private var featureURL:String;
private var queryAttribute:String;
[Bindable]
private var bookmarkAL:ArrayList; // used by BookmarkDataGroup
private var bookmarkSO:SharedObject;
private var bookmarkSOAL:ArrayList; // stored in bookmarkSO
private var selectedindex:int = 0;
private function init():void
if (configXML)
//labels
bookmarksLabel = configXML.labels.bookmarkslabel || "Bookmarks";
//query information
featureURL = configXML.queryinfo.featureURL;
queryAttribute = configXML.queryinfo.attribute;
bookmarkAL = new ArrayList();
try
bookmarkSO = SharedObject.getLocal(BOOKMARKS);
catch (err:Error)
trace(err);
loadBookmarks();
private function loadBookmarks():void
if (configXML)
var bookmarkList:XMLList = configXML..bookmark;
for (var i:int = 0; i < bookmarkList.length(); i++)
var name:String = bookmarkList.@name;
var icon:String = bookmarkList.@icon;
var bookmark:Bookmark = new Bookmark();
bookmark.name = name;
bookmark.icon = icon;
bookmarkAL.addItem(bookmark);
if (bookmarkSO)
bookmarkSOAL = bookmarkSO.data[BOOKMARKS] as ArrayList;
if (!bookmarkSOAL)
bookmarkSOAL = new ArrayList();
bookmarkSO.data[BOOKMARKS] = bookmarkSOAL;
else
bookmarkAL.addAll(bookmarkSOAL);
private function showBookmark(event:Event):void
var bookmark:Bookmark = ItemRenderer(event.target).data as Bookmark;
query.where = queryAttribute + "='" + bookmark.name + "'";
queryTask.execute(query, new AsyncResponder(onResult, onFault));
function onResult(featureSet:FeatureSet, token:Object = null):void
if (featureSet.features.length == 0)
Alert.show("Not found.");
else
map.extent = GraphicUtil.getGraphicsExtent(featureSet.features);
function onFault(info:Object, token:Object = null):void
Alert.show(info.toString());
</fx:Script>
<fx:Declarations>
<esri:QueryTask id="queryTask"
url="{featureURL}"
useAMF="false"/>
<esri:Query id="query"
outSpatialReference="{map.spatialReference}"
returnGeometry="true"/>
</fx:Declarations>
<viewer:WidgetTemplate id="helloWorld"
width="300" height="300">
<viewer:layout>
<s:VerticalLayout horizontalAlign="center" verticalAlign="middle"/>
</viewer:layout>
<s:DropDownList id="dropDownList1"
labelField="name"
dataProvider="{bookmarkAL}"/>
<s:Label id="lbl"
fontSize="21"
fontStyle="italic"
fontWeight="bold"/>
</viewer:WidgetTemplate>
</viewer:BaseWidget>
RobertScheitlin__GISP
Georgianna,
   Attach the corrected xml and I will see what the issue is.
GeorgiannaStrode
I didnot really change anything in the xml file. i supposed its still the mxml file's problem. the codes of xml are below:
<?xml version="1.0" ?>
<configuration>
 <queryinfo>
  <!-- URL of map service feature layer to query -->
  <featureURL>http://labinsw2010.freac.fsu.edu/ArcGIS/rest/services/swfwmd/control2/MapServer/10</featureURL>
  <!-- name of attribute in map service layer to query -->
  <attribute>ctyname</attribute>
 </queryinfo>
 <!-- bookmark names are checked against the specified attribute -->
 <bookmarks>
  <bookmark name="Alachua"></bookmark>
  <bookmark name="Baker"></bookmark>
  <bookmark name="Bay"></bookmark>
 </bookmarks>
 <queryinfo2>
  <featureURL>http://labinsw2010.freac.fsu.edu/ArcGIS/rest/services/swfwmd/control2/MapServer/12</featureURL>
  <attribute>quad</attribute>
 </queryinfo2>
 <bookmarks2>
  <bookmark2 name="5237"></bookmark2>
 </bookmarks2>
</configuration>
Georgiana,
   First thing is there is no quad in your data that has a value of 5237... But when you do get a valid value entered into your xml file then this is the updated showbookmark2 code.
private function showBookmark2(event:Event):void
    query.where = queryAttribute2 + "='" + dropDownList2.selectedItem.name + "'";
    queryTask.url = featureURL2;
     else
      map.extent = GraphicUtil.getGraphicsExtent(featureSet.features) ;
GeorgiannaStrode
Robert:
Thanks! The code
turns out very important. I added to every showBookmark function and it works pretty well. Also, in your codes I found that , e.g., in loadBookmark2 function, you used
bookmarkSO2.data[BOOKMARKS] = bookmarkSOAL;
, but it actually should be
bookmarkSO2.data[BOOKMARKS] = bookmarkSOAL2;
Now that I have most things working well, except for one layer that works unproperly. The url is http://labinsw2010.freac.fsu.edu/ArcGIS/rest/services/swfwmd/control2/MapServer/3. The difference of this layer from other layers is that it has very long fields name, for example,
base_and_survey.sde.SWFWMD_CONTROL_09_28_2010.swfwmd_hyd (Type: esriFieldTypeString, Alias: swfwmd_hyd, Length: 254 )
and
base_and_survey.sde.SWFWMD_CONTROL_09_28_2010.freacid (Type: esriFieldTypeDouble, Alias: FREACID99)
I have other layers working fine. so it might be the layer's problem or the attribute names' problem.
For your reference, the county layer (url is http://labinsw2010.freac.fsu.edu/ArcGIS/rest/services/swfwmd/control2/MapServer/10). the attribute names is as simple as:
ctyname (Type: esriFieldTypeString, Alias: ctyname, Length: 15 )
I used swfwmd_hyd, freacid, etc, and only swfwmd_hyd did not give me an operation error. The thing about swfwmd_hyd, still, is that it does not load data right.  I'm stuck in this layer right now
Georgianna,
   So post the xml code that you are attempting.
GeorgiannaStrode
the xml of the SWFWMD layer is:
 <queryinfo2>
  <featureURL>http://labinsw2010.freac.fsu.edu/ArcGIS/rest/services/swfwmd/control2/MapServer/3</featureURL>
  <attribute>swfwmd_hyd</attribute>
 </queryinfo2>
 <bookmarks2>
  <bookmark2 name="CYP043"></bookmark2>
  <bookmark2 name="900012"></bookmark2>
  <bookmark2 name="19966"></bookmark2>
  <bookmark2 name="17500"></bookmark2>
 </bookmarks2>
Georgianna,
   A couple of things one a point feature does not have an extent so your zooming code will not work for point layers. Two your xml has to use the full attribute name.
<queryinfo2>
  <attribute>base_and_survey.sde.SWFWMD_CONTROL_09_28_2010.swfwmd_hyd</attribute>
 </queryinfo2>
 <bookmarks2>
 </bookmarks2>
Georgianna,
   Here is how you would handle point layers:
     }else if(featureSet.features.length == 1){
      if(featureSet.features[0].geometry is MapPoint)
       map.scale = 24000;
       map.centerAt(featureSet.features[0].geometry as MapPoint);
      }else{
     else
Also a couple of more things we missed in load bookmarks2:
   private function loadBookmarks2():void
    if (configXML)
     var bookmarkList:XMLList = configXML..bookmark2;
      var bookmark2:Object = new Object();
      bookmark2.name = name;
      bookmark2.icon = icon;
      bookmarkAL2.addItem(bookmark2);
    if (bookmarkSO2)
     bookmarkSOAL2 = bookmarkSO2.data[BOOKMARKS2] as ArrayList;
     if (!bookmarkSOAL2)
      bookmarkSOAL2 = new ArrayList();
      bookmarkSO2.data[BOOKMARKS2] = bookmarkSOAL2;
     else
      bookmarkAL2.addAll(bookmarkSOAL2);
Georgianna,
   Here is what the code looks like completely cleaned up removing unused stuff.
<?xml version="1.0" encoding="utf-8"?>
       x="600" y="300"
       layout="absolute"
       widgetConfigLoaded="init()" >
 <fx:Script>
  <![CDATA[
   import com.esri.ags.geometry.MapPoint;
   //labels
   [Bindable]
   [Bindable]
   private var bookmarksLabel2:String;
   //query info
   [Bindable]
   private var featureURL2:String;
   private var queryAttribute2:String;
   [Bindable]
   [Bindable]
   private var bookmarkAL2:ArrayList;
    if (configXML)
     //labels
     bookmarksLabel = configXML.labels.bookmarkslabel || "Option 1";
     bookmarksLabel2 = configXML.labels.bookmarkslabel2 || "Option 2";
     //query information
     featureURL2 = configXML.queryinfo2.featureURL;
     queryAttribute2 = configXML.queryinfo2.attribute;
    loadBookmarks();
    bookmarkAL2 = new ArrayList();
    loadBookmarks2();
    if (configXML)
      var bookmark:Object = new Object();
    query.where = queryAttribute + "='" + dropDownList1.selectedItem.name + "'";
     if (featureSet.features.length == 0){
       map.scale = 24000;
      }else{
     }else{
    if (configXML)
       map.scale = 24000;
      }else{
     }else{
 </fx:Script>
 <fx:Declarations>
      url="{featureURL}"
      useAMF="false"/>
 </fx:Declarations>
 <viewer:WidgetTemplate width="300" height="180">
  <viewer:layout>
  </viewer:layout>
  <s:Label text="{bookmarksLabel}" />
       labelField="name"
  <s:Label text="{bookmarksLabel2}" />
  <s:DropDownList id="dropDownList2"
       labelField="name"
       change="showBookmark2(event)"
       dataProvider="{bookmarkAL2}"/>
  <s:Label id="lbl"
     fontSize="21"
     fontStyle="italic"
     fontWeight="bold"/>
and the xml:
<configuration>
 <queryinfo>
 </queryinfo>
 <bookmarks>
  <bookmark name="Alachua"/>
  <bookmark name="Baker"/>
  <bookmark name="Bay"/>
  <bookmark name="Leon"/>
 </bookmarks>
 <queryinfo2>
 </queryinfo2>
 <bookmarks2>
  <bookmark2 name="CYP043"/>
  <bookmark2 name="900012"/>
  <bookmark2 name="19966"/>
  <bookmark2 name="17500"/>
 </bookmarks2>
 <labels>
  <bookmarkslabel>Choose a county from the droplist</bookmarkslabel>
  <bookmarkslabel2>Choose a quad from the droplist</bookmarkslabel2>
 </labels>
</configuration>
GeorgiannaStrode
Hi Robert:
I feel bad for bringing troubles to you. 😉
Anyway i tried the codes u sent to me, i got 2 errors which are these 2 lines in showBookmark2 function:
and
in the xml file i am using:
 <queryinfo2>
  <featureURL>http://labinsw2010/ArcGIS/rest/services/swfwmd/control2/MapServer/14</featureURL>
 </queryinfo2>
 <bookmarks2>
 </bookmarks2>
I tried the old codes too, and these new codes, neither works. if it is true that we need to use different codes for point zoom from those used for polygon zoom, i think there is something tiny that needs to be fixed here.
