how to publish a mapservice with a query function
2498
01-09-2013 10:14 PM
trannoyronan
dear all,
i am looking for a solution to publish a map service with a query parameters
for example : i have  servicemaplayer of  parcel and building
then i want to only show a town by using a fields "CITY" or "ZIP" (common to all my layers) like a query or a thematic
    <esri:ArcGISDynamicMapServiceLayer
        load="myMap.extent = myKansasLayer.fullExtent"
        id="myKansasLayer"
        query="city like "louisville"
        url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M..." />
thanks
Rt
happy new year
IvanBespalov
take a look on layer definitions property for ArcGISDynamicMapServiceLayer
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags">
 <!-- ArcGIS API 3.1 -->
 <!-- Adobe SDK 4.6 -->
 <s:layout>
  <s:VerticalLayout paddingBottom="10"
        paddingLeft="10"
        paddingRight="10"
        paddingTop="10"
        gap="10"/>
 </s:layout>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.events.LayerEvent;
   import com.esri.ags.layers.supportClasses.LayerDefinition;
   import mx.collections.ArrayCollection;
   import mx.utils.StringUtil;
   import spark.events.IndexChangeEvent;
   [Bindable]
   private var definitions:Array;
   [Bindable]
   private var visibleLayers:ArrayCollection = new ArrayCollection([1]);
   [Bindable]
   private var landuseNames:ArrayCollection = new ArrayCollection(
     "GENERAL COMM. AND OFFICE",
     "INDUSTRIAL",
     "MULTI-FAMILY RESIDENTIAL",
     "PARKS, CEMETERIES, ETC.",
     "PUBLIC AND SEMI-PUBLIC",
     "SINGLE FAMILY RESIDENTIAL",
     "VACANT AND UNDEVELOPED"
   [Bindable]
   private var definitionConditions:ArrayCollection = new ArrayCollection(
     "like",
     "equals"
   [Bindable]
   private var defPart1:String = "LANDUSE_NAME";
   protected function onSetDefinitionClick(event:MouseEvent):void
    definitions = new Array(); // reset definitions
    var layerDefinition:LayerDefinition = new LayerDefinition();
    layerDefinition.layerId = 1; // "LandUse"
    if (ddlConditions.selectedIndex == 1) // equals
     layerDefinition.definition = StringUtil.substitute("{0} = '{1}'", defPart1, ddlValues.selectedItem);
    else // like
     layerDefinition.definition = StringUtil.substitute("{0} like '%{1}%'", defPart1, txtInput.text);
    definitions.push(layerDefinition);
    // set cursor busy, and restore it after update ended
    map.cursorManager.setBusyCursor();
    dynamicLayer.addEventListener(LayerEvent.UPDATE_END,
     function onUpdateEnd(event:LayerEvent):void {
      dynamicLayer.removeEventListener(LayerEvent.UPDATE_END, onUpdateEnd);
      map.cursorManager.removeBusyCursor();
    // update layer
    dynamicLayer.refresh();
   protected function onClearDefinitionClick(event:MouseEvent):void
    definitions = null; // remove definitions
    // update layer
   protected function onConditionChange(event:IndexChangeEvent):void
    // switch inputs
    if (ddlConditions.selectedIndex == 0) //like
     txtInput.visible = txtInput.includeInLayout = true;
     ddlValues.visible = ddlValues.includeInLayout = false;
    else
     txtInput.visible = txtInput.includeInLayout = false;
     ddlValues.visible = ddlValues.includeInLayout = true;
 </fx:Script>
 <s:HGroup verticalAlign="middle" gap="10">
  <s:Label text="{defPart1}" />
  <s:DropDownList id="ddlConditions"
      selectedIndex="0"
      dataProvider="{definitionConditions}"
      change="onConditionChange(event)"/>
  <s:TextInput id="txtInput"
      width="250"
      text="PUBLIC"/>
  <s:DropDownList id="ddlValues"
      selectedIndex="0"
      width="250"
      dataProvider="{landuseNames}"
      visible="false"
      includeInLayout="false" />
  <s:Button label="Set definition"
      click="onSetDefinitionClick(event)" />
  <s:Button label="No definition"
      click="onClearDefinitionClick(event)" />
 </s:HGroup>
 <esri:Map id="map">
  <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer"
             url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer"
             layerDefinitions="{definitions}"
             visibleLayers="{visibleLayers}"/>
 </esri:Map>
</s:Application>
layer definition not set
with layer definition
From REST API help
Definition expression allows you to filter the features of individual layers in the exported map by specifying definition expressions for those layers.
