how to pass geometry from one window to anoher...
1608
11-20-2011 09:31 PM
srinivasreddy
I am working on flex 2.2 API and flash 4, i have two applications,such that all the queries based on spatial extent and that result will appear on first application if once user will move from this application to second application by button click on the first application i want to pass the queried geometry from first application to second.....
How can i do this......
RajendraShelar
hi,
what do u mean by application here, is it widget/popup or new flex app?
srinivasreddy
Thanks for ur quick reply....
new flex app ..........
RajendraShelar
hhhmmm... you can use querystring. i mean when u open new FLEX app using navigatetourl (e.g. http:///abc/newapp.html). you pass geometry as query string param...
then in new FLEX app you access query string.
refer below link for more info.
http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf626ae-7fe8.html
