How to parse the result in Flex after calling a SOE?
1181
12-26-2012 03:21 PM
XintaoLiu
Occasional Contributor II
I created a rest SOE using VS2010 C#, and then deployed it on server machine. How to call the Rest SOE in Flex Client? Any example or suggestion? Thanks in advance!
XintaoLiu
Or may I ask that how to call Rest SOEs in Flex and parse the result Json to get valid values?
IvanBespalov
Occasional Contributor III
how to call
ESRI sample "SOE GetElevations" demonstrates how to create own Task based on BaseTask.
All the Flex API samples are also included in the Flex API Library download.
how to parse
It depends on your server object extension response. What is your SOE response format? JSON, xml, amf ?..
For example: this service SOE response format is JSON - must be pasrsed as JSON.
DasaPaddock
You can also use the JSONTask if you don't want to create your own task:
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/tasks/JSONTask.html
MarkDeaton
Xinato,
Here's a FlexViewer widget I wrote; it calls an elevation data SOE through REST and then handles the resulting JSON.
http://www.arcgis.com/home/item.html?id=b9d247c297f144459854751740f59f68
The SOE URL is here:
http://sampleserver6.arcgisonline.com/arcgis/rest/services/Elevation/WorldElevations/MapServer/exts/ElevationsSOE_NET/ElevationLayers/0/GetElevations
I use a Flex HTTPService object to make the call. I do it this way because I wrote the code a while ago. You might also use a BaseTask to do the same thing.
Here's the MXML declaration:
<s:HTTPService showBusyCursor="true" method="POST" id="websvcElevations" url="{_configXML.elevationSOEURL}" resultFormat="text"/>
And here's a bit of the code that makes the call and handles the response:
var sGeoms:String = JSONUtil.encode( [ event.graphic.geometry ] );
var oParams:Object = {
 "f"    : "json",
 "geometries" : sGeoms
// Send geometries off to SOE to get elevations
var atToken:AsyncToken = websvcElevations.send( oParams );
atToken.addResponder( new AsyncResponder(
 //--- Handle results from elevation profile SOE ---//
 function( event:ResultEvent, token:Object ):void {
  try {
   var oResult:Object = JSONUtil.decode( event.result.toString() );
   if ( oResult.hasOwnProperty( "error" ) )
    showError( "The server returned an error:\n" + oResult.error.message );
   else { ... }
I hope that helps.
XintaoLiu
Thank you all for your replies! I have solved it, but just come back to look the posts.
