How to open application on last map extent in flex
6567
10
10-19-2015 03:52 AM
akshayloya
When I close my flex application or re-login it, map refreshes to initial extent. I want to open my application on same extent on which I've logged-out or close the application. Any idea on how I can go about it.
Any help will be appreciated.
Regards,
Akshay
RobertScheitlin__GISP
Akshay,
   This thread is close to what you are looking for (though the code was developed for the Sample Flex Viewer the concept is similar).
Save session state
Akshay,
Save session state
akshayloya
Hi Robert,
Can you please summarise for last extent thing. I'm getting bit confused with so many things in that thread.
Thanks
Akshay,
   Most of the follow-on posts to that thread have to do with saving the TOC checked layer states and other stuff. The basic saving of the maps extent code is in the zip I provided. This will only be code you can learn from though as this code was developed for the Sample Flex Viewer (SFV). this was the viewer before esri started to even support the viewer as a product. I don't spend time in Flex any more as it is a API that has reached mature status and is no longer updated by esri.
akshayloya
Ok. Thanks for the help.
EvelynHernandez
Why u dont try to save the last extent in a bd field and then when the user log in u get the extent that he had?
akshayloya
what is bd field exactly?
EvelynHernandez
data base field (Sorry i typed it out in spanish)
akshayloya
oh okay. Thanks !
AnthonyGiles
Honored Contributor
Akshay,
Have a look at this widget here for ideas:
http://www.arcgis.com/home/item.html?id=73a5b7824b8542fd94c878f56861dfe0
Regards
Anthony
