How to insert a shapefile from a local directory
1223
03-29-2012 11:56 PM
JamesGooding
Hi all,
I'm quite new to all this so sorry if I'm posting about something that gets asked a thousand times.
I've got ARC GIS viewer for flex running. Under the 'More...' tab I want there to be option to make a shapefile visible which I have on my PC.
Hence my coding for this part has been:
<layer label="Swift 1.5kW" type="feature" visible="false" alpha="1.0"
url="http://homepc/flexviewer/assets/layer/merge3mall"/>
where 'merge3mall' is a zip file containing all the suffixes that a shapefile incorporates (.dbf;.prj;.sbn;.sbx;.shp;.shp.xml;and .shx)
When I open the webpage I receive this error message
Swift 1.5kW layer failed to load: Fault code: Server.Error.Request
Fault info: HTTP request error
Fault details: Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://homepc/flexviewer/assets/layer/merge3mall?f=json
I'd really appreciate any help with this. I can imagine its a simple task - to insert a shapefile from a local directory - but I am in a bit of a jam.
Cheers,
James
RobertScheitlin__GISP
James,   The way you are attempting is not going to work. Local shapefiles are not supported OOTB. There is a widget in the code gallery that allows the end user to add a shapefile at runtime.
JamesGooding
Thank you. Its a shame it won't work my way.
