How to get shorest way from given points with arcgis Flex API?
1022
12-17-2010 03:57 AM
NarekGevorgyan
Hi There,
In example I have 5 points, I want to go from first point to 5th, how can I get the shortest way.
Please See attached File.
Merci!
Narek
DasaPaddock
ArcGIS Server supports this if you publish a route layer in NAServer and then you'd use the Flex API's RouteTask:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/tasks/RouteTask.html
NarekGevorgyan
Hello Dasa!
Thank you very much for help.
Kind Regards,
Narek
