How to do intersection in Flex?
7520
14
07-07-2015 07:32 AM
akshayloya
Hi All,
Can any help me with code in flex which can intersect two feature class?
Regards
RobertScheitlin__GISP
Akshay,
   The intersect ability that the Flex API has is designed for a array of geometries and a SINGLE geometry. So intersecting two feature classes is a little difficult.
Here is the Flex API docs on the GeometryService: intersect() method:
com.esri.ags.tasks.GeometryService
akshayloya
Robert,
I'm querying on one feature class and getting its geometries and passing that geometry to intersect with other layer.
Can you please share code snippet to pass array of geometries.
Regards
Akshay,
  1. So your query results, do you have more than one geometry?
  2. What is the geometry type?
  3. The layer that you want to intersect with what geometry type is it?
  4. You understand that you will have to union all the geometries of the layer into one geometry using the Geometry service right?
  5. Which geometries will be the input and which will be the intersect feature?
akshayloya
Yes more than one geometry. Yes I'm using GeometryService.
Geometry type is polygon which I'm trying to get it unioned but it is throwing an error.
Intersect feature can be point line or polygon.
Regards,
Akshay Loya
Akshay,
   The union of the layers geometries is going to be the critical part then. If you can not get the layers geometries to union using the geometry service then this is issue. Have you tried to check the layer geometry in ArcMap using the "Check Geomtery" tool?
akshayloya
Robert,
That is fine. Mine is SDE Geodatabases, it automatically check the validity of each geometry when they are uploaded.
Error:
Suspended: TypeError: Error #1034: Type Coercion failed: cannot convert com.esri.ags.geometry::Polygon@11bdc129 to com.esri.ags.events.GeometryServiceEvent.
Akshay,
   Can I see your code that you are using to do the union?
akshayloya
Robert,
This the code I'm using:
         var queryT:QueryTask = new QueryTask();
                                         queryT.url = "url";
                                         queryT.useAMF= false;
                                         var queryB:Query = new Query();
                                         queryB.outSpatialReference = map.spatialReference;
                                         queryB.returnGeometry = true;
                                         queryB.outFields = ["*"];
                                         queryB.where= "DCPDistrictCode = 123";
                                         queryT.execute(queryB, new AsyncResponder(onResultT, onFaultT));
                                         function onResultT(featureSetB:FeatureSet, token:Object = null):void
                                                var graphicProvider1:ArrayCollection = new  ArrayCollection();
                                                if (featureSetB.features.length == 0)
                                                       Alert.show(resourceManager.getString('ViewerStrings', 'SearchAlert3'));
                                                else
    for each(var myFirstGraphic:Graphic in  featureSetB.features)
                                                       var arrtest:Array= new Array;
       arrtest.push(myFirstGraphic.geometry);
responder = new mx.rpc.Responder(myGeometryService_unionCompleteHandler,myGeometryService_faultHandler);
myGeometryService.union(arrtest,responder);
                     protected function myGeometryService_unionCompleteHandler(event:GeometryServiceEvent):void
                           doQuery(event.result[0] as Geometry);
                     protected function myGeometryService_faultHandler(event:FaultEvent):void
                           Alert.show("Service temporarily unavailable. Please try again","Information")
                     protected function doQuery(geom:Geometry):void
                           query.geometry = geom;
                           query.outFields = ["*"];
                           query.outSpatialReference = map.spatialReference;
                           query.returnGeometry = true;
                           query.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
                           QueryTk.url = "url";
                           QueryTk.useAMF = false;
                           QueryTk.execute(query,new AsyncResponder(QueryIntersect,QueryIntersectFault));
                     protected function QueryIntersect(featureSetSpa:FeatureSet, token:Object = null):void
                           if (featureSetSpa.features.length = 0)
                                  Alert.show("No Records found");
                                  cursorManager.removeBusyCursor();
                           else
                                  var arrObjectId:Array=new Array();
                                  var strObjectId:String= new String();
                                  for(var i:int=0;i<featureSetSpa.features.length;i++)
                                         arrObjectId.push("'" +FeatureSet+ "'");
                                  strObjectId = arrObjectId.toString() ;
                     protected function QueryIntersectFault(featureSet:FeatureSet, token:Object = null):void
                           Alert.show("Service temporarily unavailable. Please try again","Information");
Akshay,
  This portion of your code concerns me:
  if (featureSetB.features.length == 0){
  }else
Inside you for each loop you are recreating the arrtest array each time?...
