How to Display Attachments (ArcGIS Viewer for Flex)?
5427
35
02-02-2011 04:38 AM
RamonLeal_Pessoa
How to display attachment on the ArcGIS Viewer for Flex?
I would like to display jpeg images attachments of "OperationalLayers" with "SimpleInfoWindowWidget" or "InfoPopupWidget"...
Is this possible?
How to do?
Thanks!
ChrisBrannin
This also does not work. Do I need to have these images in the attributes? This is what my code looks like:
<multiimagefield linkprefix="http://gis.*****/flex/assets/images/img/" linksuffix="globe.png,default.png,Splash.jpg" nexttooltip="Next" prevtooltip="Prev">URL</multiimagefield>
Thanks again for all the help!
RobertScheitlin__GISP
Chris,
   Yes for the multiImages to work the values have to come from the attribute field.
ChrisBrannin
So I having an issue with getting my hyperlinks to actually link to their respected websites. What is happening(or not) when the popup is open the hyperlink shows but is not clickable.
Chris,
  Due to lack of detail, I really can not say... Maybe you should post your xml.
ChrisBrannin
Robert,
here is the code:
<linkfield icon_or_txt_or_img="txt" linkalias="UWM" linkprefix="http://www4.uwm.edu" linksuffix="/pps/Sustainability/CampusInit/renewable-energy.cfm">Hyperlink</linkfield>
Cheers
Chris
Chris,
   Can you give me a complete url that should work for this? and an example of that is in the Hyperlink field for one of the features?
ChrisBrannin
Robert,
This is exactly how it is displayed in the Hyperlink field within the attribute table:
http://www4.uwm.edu/pps/Sustainability/CampusInit/renewable-energy.cfm
Chris,
   OK then you don't need anything in the linkprefix and suffix then
<linkfield icon_or_txt_or_img="txt" linkalias="UWM" linkprefix="" linksuffix="">Hyperlink</linkfield>
because currently this is what is happening then:
http://www4.uwm.eduhttp://www4.uwm.edu/pps/Sustainability/CampusInit/renewable-energy.cfm/pps/Sustai...
ChrisBrannin
Robert,
Am I missing where to place the text that I would Like to hyperlink?
<fields>NAME,Type,Hyperlink</fields>
    <titlefield>Type</titlefield>
    <links>
<linkfield icon_or_txt_or_img="txt" txt="Hyperlink" linkalias="" linkprefix="" linksuffix="">Hyperlink</linkfield>
</links>
Chris,
   Here is what you are asking I think.
<links>
<linkfield icon_or_txt_or_img="txt" linkalias="Click Here" linkprefix="" linksuffix="">Hyperlink</linkfield>
</links>
There is no such attribute as txt = "".
