How to change the map extent from a selected item in a data grid
993
09-22-2011 05:25 AM
MartinSiwek
I've setup a query task that calls features from an ArcGIS Map Service and populates an mx datagrid with it's attributes.  I'm trying to write code so that when a user selects an item in the data grid that it zooms to it in the map.  Any suggestion about how I would go about this?
Thanks!
ZahidChaudhry
Thanks!
I assume that grid contain Lat/Long, ...on row select creat a mappoint and then call centerAt() function and set scale or level whatever is needed....here is API Reference
[HTML]centerAt () method
public function centerAt(mapPoint:MapPoint):void
Recenters the map at the specified location.
Parameters
mapPoint:MapPoint �?? The point to center at.[/HTML]
and Example...
http://help.arcgis.com/en/webapi/flex/samples/index.html#/Geocode_an_address/01nq00000068000000
