How to add an image/text dynamically on the map at desired position
972
07-19-2012 05:21 AM
ShaningYu
Honored Contributor
In one of previous thread, http://forums.arcgis.com/threads/62580-How-to-add-a-text-(label)-or-an-image-on-map-at-a-desired-pos..., I questioned how to add an image/text on the map at desired position.  From the response, I used the approach of adding a static image.  It works.  However, I also plan to print/export this image/text with the map.  Using ESRI's PrintWidget (V3.0), the static image/text is filtered out.  Now, I have to add a dynamic image/text on the map at a desired position in order to get it printed/exported with the map.  How can this be easily coded?  Is there any good sample?  Thanks.
ShaningYu
Honored Contributor
ShaningYu
Honored Contributor
