How do you populate Feature.layerDetails
1046
04-26-2011 11:41 AM
WaltBulawa
After the following lines:
private var myFeatureLayer:FeatureLayer;
myFeatureLayer = new FeatureLayer(url_of_myLayer);
Looking at the myFeatureLayer.layerDetails in the debugger shows a null for its value.
How would I get layerDetails populated for this feature layer?  Any action script code (non-xml) example to show this would be very much appreciated.  Thanks.
RobertScheitlin__GISP
Walt,
   You have to wait for the layer to be loaded.
                            private function getMyLayerDeatils():void{
                                if (myFeatureLayer && !myFeatureLayer.loaded)
     myFeatureLayer.addEventListener(LayerEvent.LOAD, myFeatureLayer_loadHandler);
     function myFeatureLayer_loadHandler(event:LayerEvent):void
      getMyLayerDeatils();
     return;
                                //Do something here
WaltBulawa
Thank you Robert for your help.  With your help I created the following which works:
myFeatureLayer.addEventListener(LayerEvent.LOAD,getLayerDetails);
and then:
private function getLayerDetails(event:LayerEvent):void
   var thisLayer:FeatureLayer = event.layer as FeatureLayer;
   myLayerDetails = thisLayer.layerDetails;
   myLayerFieldsArray = myLayerDetails.fields;
   if (myLayerFieldsArray.length > 0)
      for (var j:int = 0; j < myLayerFieldsArray.length; j++)
         myFieldsList.addItem(myLayerFieldsArray.name);
