How do i rotate the map view using Flex api?
1708
11-28-2010 07:12 PM
DarkoRadiceski
Hi all,
I was wondering if it is possible to rotate the map view in the FLEX api? I am using the new 2.1 flex viewer.
I remember that in the WebADF components there was a rotation property on the map.
A dodgy way would be for me to use the data frame property rotation and publish 4 map views with different rotation. But i would have to use dynamic map rendering so i dont waste space.
Any advice?
Cheers
Dan
AaronNash
have you found an answer to this? I was wondering the same thing
YungKaiChin
Not sure if it is what you want.
You can set the rotation of the DisplayObject instance, in this case your map.
SamKrueger1
Is this possible with the 3.6 Viewer? Would like to implement this function in a flex app I've already created.
DasaPaddock
