How can i GET visibleLayers ??
1226
02-10-2012 03:15 AM
aureliensebert
in an application I try to save the layer properties (transparency, visible, etc. ..) but I can not retrieve visibleLayers from an ArcGISDynamicMapServiceLayer because visibleLayers is a method used to SET (not GET) the visible layers for the map service.
someone has an idea ?
      for each (var layer:Layer in map.layers)      {      if (layer is ArcGISDynamicMapServiceLayer){      var visLayers:Array =[];      //NOT WORK !!!!!      visLayers = ArcGISDynamicMapServiceLayer(layer).visibleLayers;          }          }
Aurélien SEBERT
CAUE DU NORD
FRANCE
RobertScheitlin__GISP
Aurélien,
   I don't think you are understanding the documentation.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/ArcGISDynamicMapServiceLayer.html
visibleLayers    property
visibleLayers:ArrayCollection
Sets the visible layers of the exported map. By default, the visible layers are as defined by the default visibility in LayerInfo.
This property can be used as the source for data binding.
Implementation
    public function get visibleLayers():ArrayCollection
    public function set visibleLayers(value:ArrayCollection):void
So you can get the visibleLayers from the ArcGISDynamicMapServiceLayer as an ArrayCollection.
Aurélien,
Implementation
aureliensebert
thank you ... 🙂 it's work
I did not understand the documention --- French (or only me)  are bad in English
     var visLayers:ArrayCollection = new ArrayCollection;
     Alert.show(visLayers.source.join(","));
     // ex : result : 0,1,2,4,7,8
