High quality print with Flex
4251
13
09-28-2010 05:09 AM
erictruchon
Hello
Our firm has developed an application in Flex and we publish the assessment roll for many municipalities.
Prior to Flex, we were using ArcIMS.
Some of our clients find that our print tool in Flex has lost quality from ArcIMS and I agree with them.
I watched the new version of the API in Flex (version 2.1) and I have not seen an example of printing tool in high quality. (just a snap shot)
I tried to find an example and I have not found. But I read that it would be possible to do it.
Where could I find a solution?
Thank you in advance
Greetings
erictruchon
Thank you very much hawkeye81x for information, I understand better now
Last question: Does it requires ArcGIS is installed on the server?
Thanks again
EokNgo
Thanks again
I assume by ArcGIS you mean ArcGIS Desktop, you shouldn't need it if you're printing just the map.
erictruchon
Voilà
My solution with AlivePDF to produce good quality printing
private function generatePDF():void
  var layer:ArcGISDynamicMapServiceLayer = map.getLayer(map.layerIds[0]) as ArcGISDynamicMapServiceLayer;
  var imageParams:ImageParameters = new ImageParameters();
  var mapImage:MapImage = new MapImage();
  var extent_map:Extent = map.extent
  var x1:Number = extent_map.xmin
  var x2:Number = extent_map.xmax
  var y1:Number = extent_map.ymin
  var y2:Number = extent_map.ymax
  imageParams.format = "jpg"; //png
  imageParams.width = 2048;   // max default width arcgis server
  imageParams.height = Math.round(2048*(y2-y1)/(x2-x1));
  var extent:Extent = new Extent(x1, y1, x2, y2);
  var sr:SpatialReference = new SpatialReference(2145)
  imageParams.imageSpatialReference = sr;
  imageParams.extent = extent;
  imageParams.dpi = 150;
  layer.exportMapImage(imageParams,new AsyncResponder(onResult, onFault))
     function onResult(mi:MapImage, token:Object = null):void
     try
mapImage = mi;
var my_url:String = mapImage.href;
my_url = my_url.replace("server_name", "server_url")
var urlLoader:URLLoader = new URLLoader();
urlLoader.dataFormat = URLLoaderDataFormat.BINARY;
urlLoader.addEventListener(Event.COMPLETE, loaderComplete);
        urlLoader.load(new URLRequest(my_url));
     catch (error:Error)
Alert.show(info.toString(), "Export Problem");
      function onFault(info:Object, token:Object = null) : void
private function loaderComplete(event:Event):void
   switch  (my_page.text)
case "8 1/2 x 11":
   var myPDF : PDF = new PDF (Orientation.LANDSCAPE, Unit.MM, Size.LETTER);
   myPDF.setDisplayMode(Display.FULL_PAGE,Layout.SINGLE_PAGE );
   myPDF.addPage();
   var rs:Resize= new Resize(Mode.FIT_TO_PAGE,Position.LEFT);
   myPDF.addImageStream(ByteArray(event.target.data), ColorSpace.DEVICE_RGB, rs  );
   myPDF.beginFill ( new RGBColor (0xFFFFFF));
   myPDF.lineStyle ( new RGBColor ( 0xFFFFFF ), 1, .1, 1, CapsStyle.SQUARE, JointStyle.MITER );
   myPDF.drawRect ( new Rectangle (221, 11, 60, 193 ));
   myPDF.endFill ( );
   myPDF.addImageStream( new logo as ByteArray, ColorSpace.DEVICE_RGB, null,224, 15, 25, 11 );
   myPDF.addImageStream( new legende as ByteArray, ColorSpace.DEVICE_RGB, null,216, 45, 37, 95 );
   break;
case "11 x 17":
    var myPDF : PDF = new PDF (Orientation.LANDSCAPE, Unit.MM, Size.TABLOID);
    myPDF.addPage();
           myPDF.drawRect ( new Rectangle (365, 11, 80, 257 ));
           myPDF.endFill ( );
    myPDF.addImageStream( new logo as ByteArray, ColorSpace.DEVICE_RGB, null,370, 15, 30, 13 );
    myPDF.addImageStream( new legende as ByteArray, ColorSpace.DEVICE_RGB, null,365, 65, 40, 100 );
    break;
myPDF.save(Method.REMOTE,"http://my_server_url/php/create.php",Download.INLINE,"map.pdf")
/*php file create.php
<?php
$method = $_GET['method'];
$name = $_GET['name'];
if ( isset ( $GLOBALS["HTTP_RAW_POST_DATA"] )) {
   $pdf = $GLOBALS["HTTP_RAW_POST_DATA"];
   header('Content-Type: application/pdf');
   header('Content-Length: '.strlen($pdf));
   header('Content-disposition:'.$method.'; filename="'.$name.'"');
   echo $pdf;
} else echo 'An error occured.';
TomSchuller
This could also be an alternative if you are running on an ArcGIS server 10 (v10 is a requirement):
  http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
It's based on a SOE (ServerObjectExtension) which runs on the Java and .Net version of ArcGISServer.
The communication is based on REST, so any client/platform can use it.
There is a Flex widget provided with.
Tom
