Hide Zoom to Button in Infowindow
4642
6
03-20-2013 06:31 AM
MattSheehan
Is there a simple way to hide the default 'Zoom To' button in the InfoWindow.
http://www.webmapsolutions.com/blogimg/zoom_to.png
We have found in the mobile ArcGIS Online apps we are building this can cause the app to crash.
--Rory
HeatherGonzago
--Rory
Hi Rory,
There is a known-limit when working with pop-up windows in mobile applications created with version 3.1. If doing so, please note that you will need to either:
   1 -  add both mx.swc and sparkskins.swc to your project, or
  2 -   update the PopUpRendererSkin class and remove references to the RelationshipInspector component.
This is doc'd at http://resources.arcgis.com/en/help/flex-api/concepts/index.html#/Mobile_applications_with_Flex/017p...
and also doc'd at the FAQ's as Why is my mobile application throwing errors when working with pop-up windows?
http://resources.arcgis.com/en/help/flex-api/concepts/index.html#/FAQ/017p00000016000000/
HTH,
Heather
RobertScheitlin__GISP
Rory,
  Sure if you look at the PopUpInfo documentation you will see showZoomToButton:
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/portal/supportClasses/PopUpInfo.htm...
RhettZufelt
MVP Notable Contributor
Not sure about mobile, but the simplest way in flexviewer is to set that tag in the popupconfig.xml file and can be set differently for each sub layer.
      <showzoomtobutton>false</showzoomtobutton>
as documented here:  http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Pop_up_configuration_files/01m3... at bottom of page.
R_
HeatherGonzago
--Rory
Hi Rory,
HTH,
Heather
MattSheehan
Thanks for the replies all. It was a 3.1 issue. Just grabbed 3.2 and so far all looks good.
--Rory
MattSheehan
I should have added, I am also following Heathers advice. Thanks all again.
KenBuja
MVP Esteemed Contributor
You should click the check mark on her post to signify it answered your question.
