hide the navigation bar in flex Application
3426
05-16-2013 12:31 PM
lifeEsri
hi
how to hide the navigation bar in flex Application
some one help me please 🙂
RobertScheitlin__GISP
life Esri,
   Do you mean the Maps ZoomSlider?
map.zoomSliderVisible = false;
lifeEsri
i mean this :==>
[ATTACH=CONFIG]24394[/ATTACH]
life Esri,
   That is part of the browser not the Flex App... For questions that do not have to do with Flex you would be better off using a Google Search "hide browser address bar".
IvanBespalov
As 1 of possible solution - U can play flash in full screen,
but with some restrictions, such as no ability to use keyboard in full screen mode...
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="World Topographic Map">
 ESRI dev. team sample - http://resources.arcgis.com/en/help/flex-api/samples/01nq/01nq00000044000000.htm
 <fx:Script>
  <![CDATA[
   protected function onFullScreenButtonClick(event:MouseEvent):void
    if (stage.displayState == StageDisplayState.NORMAL)
     stage.displayState = StageDisplayState.FULL_SCREEN;
    else
     stage.displayState = StageDisplayState.NORMAL;
 </fx:Script>
 <s:layout>
  <s:VerticalLayout horizontalAlign="center"
        paddingTop="10"
        gap="10"/>
 </s:layout>
 <fx:Declarations>
  <esri:Extent id="initialExtent"
      xmin="-13635000" ymin="4541000" xmax="-13625000" ymax="4547000">
   <esri:SpatialReference wkid="102100"/>
  </esri:Extent>
 </fx:Declarations>
 <s:Button id="btnFullScreen"
     icon="http://s.xanga.com/images/settings/icon_fullscreen.gif"
     label="Toggle fullscreen"
     click="onFullScreenButtonClick(event)"/>
 <esri:Map extent="{initialExtent}">
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
 </esri:Map>
</s:Application>
Ivan,
Actually that has changed in the Flash Player 11.3 and greater.
Here is the updated example Code:
               creationComplete="init()">
    <fx:Script>
        <=!=[=C=D=A=T=A=[
            import com.esri.ags.geometry.MapPoint;
            import mx.controls.Alert;
            import mx.core.FlexGlobals;
            import mx.events.CloseEvent;
            import mx.utils.URLUtil;
            private var extCenter:MapPoint;
                if(flashVersion.major == 11 && flashVersion.minor >= 3){
                    var bUrl:String;
                    if(FlexGlobals.topLevelApplication.url.indexOf("file")>-1){
                        bUrl = "local";
                    }else{
                        bUrl = URLUtil.getServerName(FlexGlobals.topLevelApplication.url);
                    Alert.show("You are about to switch to full screen mode. You must click allow " +
                        "when you see an overlay that says '" + bUrl + "' is now full screen. Press esc to exit. " +
                        "You must click allow to enable keyboard interaction. " +
                        "Do you want to switch full screen mode?", "Warning", Alert.YES|Alert.NO, null,
                        alertClickHandler, null, Alert.YES);
                }else{
                    /* If not in full screen mode, ask if they want to switch to full screen mode. */
                    Alert.show("You are about to switch to full screen mode, that limits your interaction " +
                        "with the map in a couple of ways. You can not enter text into widgets like " +
                        "the parcel search widget or other widgets when you are in full screen mode. " +
                        "Certain keyboard shortcuts will not work in full screen mode also. " +
            private var flashVersion:Object = new Object();// Object to hold the Flash version details
            protected function getPlayerVersion():void {
                var versionNumber:String = Capabilities.version;// Get the whole version string
                var versionArray:Array = versionNumber.split(",");// Split it up
                var length:Number = versionArray.length;
                var osPlusVersion:Array = versionArray[0].split(" ");// The main version contains the OS (e.g. WIN), so we split that off as well.
                // Populate the version object (the OS is a string, others are numbers):
                flashVersion["os"] = osPlusVersion[0];
                flashVersion["major"] = parseInt(osPlusVersion[1]);
                flashVersion["minor"] = parseInt(versionArray[1]);
                flashVersion["build"] = parseInt(versionArray[2]);
            protected function alertClickHandler(event:CloseEvent):void
                if (event.detail==Alert.YES){
                    extCenter = map.extent.center;
                        systemManager.stage.displayState = StageDisplayState.FULL_SCREEN_INTERACTIVE
                    }else{
                        systemManager.stage.displayState = StageDisplayState.FULL_SCREEN;
                    var timer:Timer = new Timer(500, 1);
                    timer.addEventListener(TimerEvent.TIMER_COMPLETE, timerComplete);
                    timer.start();
                    function timerComplete(evt:TimerEvent):void{
                        map.centerAt(extCenter);
            protected function exitFullScreen(evt:FullScreenEvent):void
                if(!evt.fullScreen){
                    timer.start();
            protected function init():void
                systemManager.stage.addEventListener(FullScreenEvent.FULL_SCREEN, exitFullScreen);
                getPlayerVersion();
    </fx:Script>
    <s:layout>
                          paddingTop="10"
                          gap="10"/>
    </s:layout>
    <fx:Declarations>
        </esri:Extent>
    </fx:Declarations>
    <esri:Map extent="{initialExtent}" id="map">
    </esri:Map>
</s:Application>
Here is the changes that have to be made to the index.template.html. See attached
//Add
params.allowFullScreenInteractive = "true";
//Add
<param name="allowScriptAccess" value="sameDomain" />
