Help with Feature Layer SELECTION_SUBTRACT
2358
11-30-2011 05:35 PM
DaveEaton
I am having problems removing a selected feature from my feature layers.  I am getting the correct feature selected, but the actual removal of the graphic is not working.  The code below shows one of my feature layer selections with the SELECTION_SUBTRACT method, and its responder "removeFeaturesHandler".
case "TEL=COMNT":
   cmntLayer.selectFeatures(remQuery, FeatureLayer.SELECTION_SUBTRACT,
 new AsyncResponder(removeFeaturesHandler, removeFeaturesFault));
protected function removeFeaturesHandler(features:Array, token:Object = null):void
    for each (var remgraphic:Graphic in features)
     myGraphicsLayer.remove(remgraphic);
I've been debugging this and the remgraphic variable is populated with a graphic id, but it doesn't correspond to any of the graphic ids I see in the graphicProvider array.  Where am I going wrong?
DaveEaton
Should anyone stumble across this thread...the problem I was having was when I initially rendered the features I was using FeatureLayer.MODE_ON_DEMAND instead of using FeatureLayer.SELECTION_ADD.  Everything works like a charm now.
