Help to fix the white space between the datagrid scrollbars. Thanks!
3237
5
09-29-2010 03:19 PM
cristiBJ
This is done by using sample viewer.
Now I added vertical and horizontal scroll bars. Since the background is black, there is a white block between the scroll bars.  Please see attached.
How can I make the white block the same color as the background? I tried to set backgroundcolor for the datagrid but it didnot work.
Thanks in advance.
Part of the code is here:
<mx:VBox width="100%" height="100%" verticalGap="1"  horizontalGap="2" verticalScrollPolicy="on" horizontalScrollPolicy="auto" backgroundColor="gray"> <!-- horizontalScrollPolicy="on" -->
    <mx:HBox id="boxMessage" visible="{msgVisible}" includeInLayout="{msgVisible}" width="100%">
     <mx:SWFLoader id="swfMessage" source="com/esri/solutions/flexviewer/assets/flash/loader.swf" visible="false" />
     <mx:Text id="txtMessage" text="" styleName="WidgetText" width="90%"/>
    </mx:HBox>
    <mx:Repeater id="wRepeaterDisplay" width="100%" >
           <myWidgets:ParcelRecordData_Identify infoData="{wRepeaterDisplay.currentItem}" mouseOver="mouseOverRecord(event)"
      mouseOut="mouseOutRecord()" click="selectLocation(event)" valueSet="valueSetHandler(event)" paddingTop="5"/>
    </mx:Repeater>
          <mx:DataGrid id="dParams" rowCount="23" visible="false" width="399"  click="clickRecord(event)" showHeaders="false" backgroundColor="#cccccc">
                <mx:columns>
                   <mx:DataGridColumn dataField="key" headerText="Property" width="152" />
                   <mx:DataGridColumn dataField="value" wordWrap="true" headerText="Value" width="270" />
               </mx:columns>
          </mx:DataGrid>
   </mx:VBox>
cristiBJ
Anyone can help here?
RobertScheitlin__GISP
cristiBJ
You helped me out again.  Thank you ...
cristiBJ
The first link is blocked by our company websense.
I tried the 3rd one but it did not work.
The second link works for me. It was easy to implement into our sampleviewer project.
Thanks again.
BradChranko
Hi Christi and Robert-
I'd like to know which identify widget was used in this example, the one with the print option.  I'm looking for a way to print a datagrid upon a search/query.  Is there a widget out there or is it something that has to be customized.
Brad.
