Help! - Cannot add dynamically created polygon (sfv 1.3, agis 9.3.1)
1337
10-05-2010 05:48 AM
grahamcooke
I have created a polygon dynamically in my code behind. I am trying to add it into a graphics layer  and show it on the map.
Everything seems to be working ok as i step through, but the polygon is not displaying.
the FPClass.PlotTrace method returns a polygon and the code is as follows:
public function PlotTrace():Polygon
                  firingPosX = parseInt(fpFirePoint.toString().substr(0,6));
           firingPosY = parseInt(fpFirePoint.toString().substr(6,6));
                  //if a min range has been set, set up the slip bearings to change the plotting of the trace
                  if (minRange > 0)
//plot a slipped trace
                  if (hefLength > 0 && stdTraceLength == 0)
                       //plot a hef trace
                  else
               myTrace = new Polygon();
               myTrace.addRing(createFFAFiringPoint());
                  return myTrace;
createFFAFiringpoint returns an array of points used to create the polygon ring: myTrace shows in the debugger as follows:
myTrace            com.esri.ags.geometry.Polygon (@106b9b79)
            [inherited]
            defaultSymbol    com.esri.ags.symbol.SimpleFillSymbol (@10599d29)
            extent   <exception thrown by getter>
            rings     Array (@abb0ee9)
                        [0]        Array (@1070d901)
                                    [0]        flash.geom.Point (@10580629)
                                                length   717464.8361703869
                                                x          382415 [0x5d5cf]
                                                y          607054 [0x9434e]
                                    [1]        flash.geom.Point (@1055ce71)
                                                length   717308.4317941585
                                                x          382020.11968464445
                                                y          607117.7929192365
                                    [2]        flash.geom.Point (@1065e629)
                                                length   717425.8993229957
                                                x          381281.23903104366
                                                y          607720.7728738267
                                    [3]        flash.geom.Point (@10782fb1)
                                                length   717649.1139426031
                                                x          381252.6866894122
                                                y          608002.1707483521
                                    [4]        flash.geom.Point (@10782fd9)
                                                length   718632.3713444908
                                                x          383550.0679880897
                                                y          607718.5454554912
                                    [5]        flash.geom.Point (@10782241)
                                                length   717728.7598126691
                                                x          382810.00481118547
                                                y          607117.0174510777
                                    [6]        flash.geom.Point (@10580629)
                                                x          382415 [0x5d5cf]
                                                y          607054 [0x9434e]
                                    length   7
            type      "esriGeometryPolygon"
but the polygon doesn't appear on the map. i try to get the polygon from an instantiation of the FPClass, use it to create a graphic and then add the graphic to the graphics layer as follows:
            private function PlotTrace(piTraceType:String):void
                  switch (piTraceType)
                       case ("FirePoint"):
                        {        if (vwHefStd.selectedChild.id=="StdTemplate")
                                    var FPClass:FiringPointTrace = new FiringPointTrace(parseInt(txtFPCoord.text), parseInt(txtFPLeft.text), parseInt(txtFPRight.text), parseInt(txtStdLength.text),parseInt(txtStdWidth.text), parseInt(txtStdBSD.text), chkHT.selected,0,0,0,0,parseInt(txtStdAimErr.text), parseInt(txtFPMinRange.text))
                                    var polyGeometry:Geometry = new Geometry() as Polygon;
                                    polyGeometry = FPClass.PlotTrace();
                                    graphic = new Graphic(polyGeometry,sfs_dashedoutline);
                                    gfxTemplates.add(graphic);
                              //else do hef template
                        //case 2
                        //case 3
I have created gfxtemplates in the init method for the widget and added the layer to the map in the same routine.
I must be missing something but im not sure what!
hope someone can help??
RobertScheitlin__GISP
Graham,
    I seem to remember running into this issue and I had to add a spatial reference to each point or it might have been just the polygon...
grahamcooke
Hi Robert,
Thanks for your reply. I have made sure that I add a spatial reference to the points. I also realised they were points and not MapPoints so I have changed them to mappoints.
here is my code (code snips are edited down to keep this post simple)
private function createFFAFiringPoint():Array
var point:MapPoint;
                                    var i:int;
                                    var common:CommonRoutines = new CommonRoutines();
                                    var spatRef:SpatialReference = new SpatialReference(27700);
                                    try
                                                //plot a standard trace
                                                //first of all adjust the left and right of arc figures to cater for aim error and run through the routine that ensures bearings
 //are kept within the range of 6400mils (360 degs).
                                              arcLeft = common.MODO((arcLeft - aimError), 6400);
                                                arcRight = common.MODO((arcRight + aimError), 6400);
//calculate points on polygon to generate trace shape (there are always 6 points excluding firing position on standard ffa trace)
//we can't do a simple loop because although the method of calculating the point is always the same, the values we pass to the method
//vary depending on which point of the polygon we need to calculate:
                                               //plot origin and push to array
                                                point = new MapPoint(firingPosX, firingPosY, spatRef);
                                                arrPoints = new Array;
                                                arrPoints.push(point);
                                                //Point 1
                        point = common.CalculatePoint((stdTraceWidth * -1), common.Distance1(stdTraceWidth), arcLeft, firingPosX, firingPosY);
[etc.....]
            return arrPoints;
calculate point code:
public function CalculatePoint(piWidth:Number, piDistance:Number, piArc:Number, firingPointX:Number, firingPointY:Number):MapPoint
                                    var direction:Number;
                                   var targetBearing:Number;
                                    var distance:Number;
                                    var xValue:Number;
                                    var yValue:Number;
                                    try
                                                //Flex uses radians to calculate angles, user entered details in mils.
                                                direction = milsToRads(piArc);
                                                //make adjustments for targetBearing in different quadrants of an x/y grid.
                                                targetBearing = adjustAngleForQuadrant(piWidth, piDistance) + direction;
                                                //basic trig: the hypotonuse length = sqrt of the sum of the squares of the other 2 sides
                                                distance = Math.sqrt((piWidth * piWidth) + (piDistance * piDistance))
                                                //create the co-ordinates for the newly calculated point
                                                xValue = Math.sin(targetBearing) * distance + firingPointX;
                                                yValue = Math.cos(targetBearing) * distance + firingPointY;
                                                //nb some extra code may need to be added later if we start to deal with non Uk maps to determine which
                                                //spatial reference to use
                                                myPoint = new MapPoint(xValue,yValue, spatRef);
[etc]
return myPoint;
I also ensured that the polygon was spatially referenced as well:
var newTrace:Polygon = new Polygon();
newTrace = FPClass.PlotTrace()
newTrace.spatialReference = spatRef;
graphic = new Graphic(newTrace, s_lineSymbol);
however I am still having no luck....Could the problem be the symbol declaration?
<esri:SimpleLineSymbol id="s_lineSymbol" color="0xFF000" width="3" alpha="0.5"/>
I have also upgraded to the 3.5 sdk from adobe (was on 3.2 before). If you or anyone else has any other ideas I'd love to hear them!
grahamcooke
Robert,
Your solution was the correct one. You do need to spatially reference the mappoints and the polygon.
If i had used a simple fill symbol and not a simple line symbol it would have appeared having implemented your solution. When I was tweaking around to find what was wrong I changed my simplefillsymbol to a simplelinesymbol for some reason and didnt change it back.
all sorted now. 🙂
Graham,
    Good to here, I thought I remembered that being the issue.
