GraphicsLayer Symbol by GeometryType
2937
03-11-2010 07:35 AM
JoseSousa
Dear ArcGIS API Flex Team,
I've noticed that GraphicsLayer.SymbolFunction has been deprecated. Now I believe that I must use Renderer instead.
Is there a way of specifying the symbols for the GraphicsLayer for each type of geometry (Point, Polyline and Polygon)?
I've searched in the samples but I was unable to find it.
Thanks advanced,
José Sousa
DasaPaddock
The logic that was in the symbolFunction, can now be placed in a custom renderer's getSymbol function. For example:
package test
import com.esri.ags.Graphic;
import com.esri.ags.geometry.MapPoint;
import com.esri.ags.geometry.Polygon;
import com.esri.ags.geometry.Polyline;
import com.esri.ags.renderers.Renderer;
import com.esri.ags.symbols.Symbol;
public class MyRenderer extends Renderer
    public var pointSymbol:Symbol;
    public var polylineSymbol:Symbol;
    public var polygonSymbol:Symbol;
    override public function getSymbol(graphic:Graphic):Symbol
        if (graphic.geometry is MapPoint)
            return pointSymbol;
        if (graphic.geometry is Polyline)
            return polylineSymbol;
        if (graphic.geometry is Polygon)
            return polygonSymbol;
        return null;
JoseSousa
That will probably work 🙂
Thanks a lot.
José Sousa
JanicePeal
I need to accomplish the same task.  I created the renderer class in an external flex library project(MyRenderer), but how do I implement the renderer in the GraphicsLayer (mxml)?
When I tried to point the renderer to the class:
<esri:GraphicsLayer id="debugGL2" symbol="{sfs}" renderer="{test.MyRenderer}"/>
I get 1067: Implicit coercion of a value of type Class to an unrelated type com.esri.ags.renderers:Renderer.
I am fairly new at this, so apologies in advance for my naivete.  Many thanks in advance for your assistance.
RobertScheitlin__GISP
Janice,
    What does your MyRenderer code look like?
DasaPaddock
You need to pass an instance. e.g.
<esri:GraphicsLayer id="debugGL2" symbol="{sfs}" renderer="{new MyRenderer()}"/>
