Graphic Blocks Feature Layer
1155
02-23-2012 09:41 AM
by Anonymous User
Not applicable
Greetings!
    I've got an interesting issue:  I dynamically add a graphic to my map upon the completion of a geoprocess to zoom to and establish the boundary of the region on my map that I want to make edits to.  When I go to make edits however I find that the returned graphic blocks the features that underlie it so that I cannot select them for editting.  I can select features that fall outside of the border graphic with no problem but no luck on the ones that fall within it!  Any ideas how I can get around this?  I see a method on GraphicsLayers called MoveToTop but there's not another one for MoveToBack or any other means of resetting the z-order to get the behaviour I want.  Btw, selecting features works fine if I first turn off the graphic's visibility.  Also, I am using the Flex Viewer with the out-of-box Editor ... thanks!
- Bob
DasaPaddock
If you set mouseEnabled and mouseChildren to false on the Graphic it won't receive any mouse events.
DasaPaddock
by Anonymous User
Not applicable
Cool Dasa, let me give that a try and get back to you ...
by Anonymous User
Not applicable
Thanks Dasa, that did the trick!
Hey, I have another post that so far hasn't generated any positive feedback and I was wondering if you migth be able to pass it along to someone there at the team who might have some better insight into SDE issues - the link is at http://forums.arcgis.com/threads/50823-Geoprocessing-Uses-Old-SDE-Data-After-Web-Edits - thanks!
I'll mark this one answered now. I knew it was going to be something simple that I overlooked and I really appreciate the quick response!
- Bob
