Graceful recovery from layer LOAD_ERROR faults
2361
07-17-2012 08:27 AM
AndrewLiles
Is the best way to recover from a LOAD_ERROR fault (on an ArcGISDynamicMapServiceLayer, for instance) involve creating a whole new layer object? Or is there some method on the class that allows one to attempt a reload in-place? A lookover of the API docs lead me to think that there is no way to "reload" a faulted layer in place.
We're loading a fairly large number of layers and some of our clients are on less-than-ideal internet connections, so occurrences of load faults are higher than I'd like. To address this I'm adding in some more error handling/retry options to more gracefully recover from these instances instead of simply splashing out error messages or removing the layer.
DasaPaddock
You can cause it to try and reload by changing the url by appending a dummy parameter to it.
AustinDavis
Have you tried casting it to a Layer and calling the refresh() method on it. This should reload the Layer.
