Getting FeatureLayer from ArcGISDynamicMapServiceLayer
4967
7
08-01-2011 05:13 PM
shashinanjaiah
I am trying to get the Featurelayer directly form the map to add an event for infopopup on mouseover. I went through the samples and it works when I create a new instance of the feature layer and add it to the map. It duplicates my layers on the map.
structureFeatureLayer = new FeatureLayer;
    structureFeatureLayer.url = "sampleUrl";
    structureFeatureLayer.mode = "snapshot";
    structureFeatureLayer.outFields = ['FIELD_ID'];
    structureFeatureLayer.addEventListener(GraphicEvent.GRAPHIC_ADD, sLayer_graphicAddHandler);
    map.addLayer(structureFeatureLayer);
//Event Listner when the map is initially loaded
   private function sLayer_graphicAddHandler(event:GraphicEvent):void
    event.graphic.addEventListener(MouseEvent.MOUSE_OVER, onMouseOverStructure);
Can I do this without creating a new instance of feature layer without adding to the map but add an event listener to the existing Map feature layer.
Any help would be appreciated.
Thanks
cristiBJ
Any solution for this? I have the similar question too.
CedricDespierre_Corporon1
Hello,
You can access it by using map.getLayer('featurelayerid')
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Map.html#getLayer()
AndrewThomas
I'm having issues here too? Any solution to this?
How do we get from map.getLayer(DynamicMapServiceLayerID) to a feature layer?
Ideally something like this: (which doesn't work)
var myfLayer:FeatureLayer = map.getLayer(DynamicMapServiceLayerID) as FeatureLayer;
or perhaps:
var myfLayer:FeatureLayer = map.getLayer(DynamicMapServiceLayerID)[0] as FeatureLayer;
In my case I know the layer number I want
I.E.
map.getLayer(DynamicMapServiceLayerID).url + "/0"
So my interim solution is:
var layer:Layer = map.getLayer("Metadata");
var myfLayer:FeatureLayer = new FeatureLayer(layer.url + "/0");
myfLayer.id = "MetadataFeatureLayer";
myfLayer.addEventListener(GraphicEvent.GRAPHIC_ADD,fLayer_graphicAddHandler);
map.addLayer(myfLayer);
but I want to do this without adding another layer to the map.
Andrew
IvanBespalov
Andrew,
// add layer/table load event listener
myfLayer.addEventListener(LayerEvent.LOAD, onLayerLoad, false, 0, true);
dispatchEvent(new LayerEvent(LayerEvent.LOAD, myfLayer)); // the code you looked for
// map.addLayer(myfLayer);
 * Listen layer load handler
protected function onLayerLoad(event:LayerEvent):void
    // now you can work with loaded layer/table
Good luck.
AndrewThomas
Hmmmm....
Thanks, but it wasn't the result I was hoping for. Although I think it's a case of me 'having my cake and eating it too' as they say.
The fLayer_graphicAddHandler is never being run. I guess because the layer isn't actually being added to the map.
Thanks anyway.
Andrew
IvanBespalov
Andrew,
I do not understand what you want to hear, listening myfLayer.addEventListener(GraphicEvent.GRAPHIC_ADD,fLayer_graphicAddHandler);?
How are going to add "Graphic"?
As I understand, for FeatureLayer add() is not supported.
What is your task? Why fLayer_graphicAddHandler needed?
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                    xmlns:s="library://ns.adobe.com/flex/spark"
                    xmlns:mx="library://ns.adobe.com/flex/mx"
                    backgroundColor="0x9c9c9c">
 <!-- Adobe Flex SDK 4.6.0 -->
 <!-- ArcGIS API for Flex 3.0 prerelease 15.03.2012 -->
 <!-- web.zone.ee/bespiva/layerwithoutmap -->
 <s:layout>
  <s:VerticalLayout gap="10"
     paddingLeft="10"
     paddingRight="10"
     paddingTop="10"
     paddingBottom="10" />
 </s:layout>
 <s:Label text="Load layer:" />
 <s:HGroup width="100%">
  <s:TextInput id="txtUrl"
      width="100%"
      text="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/MapServer/0" />
  <s:Button label="Load"
         click="onLoadButtonClick(event)" />
 </s:HGroup>
 <s:Label text="Query results table:" />
 <s:VGroup width="100%"
         height="50%">
  <s:DataGrid width="100%"
     height="100%"
     dataProvider="{gridProvider}" />
 </s:VGroup>
 <s:Label text="Logs:" />
     height="100%">
  <s:TextArea width="100%"
     height="100%"
     id="log" />
 </s:VGroup>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.FeatureSet;
   import com.esri.ags.Graphic;
   import com.esri.ags.events.LayerEvent;
   import com.esri.ags.layers.FeatureLayer;
   import com.esri.ags.tasks.supportClasses.Query;
   import mx.collections.ArrayCollection;
   import mx.rpc.AsyncResponder;
   import mx.rpc.Fault;
   import mx.utils.StringUtil;
   [Bindable]
   private var gridProvider:ArrayCollection = new ArrayCollection();
   private var activeLayer:FeatureLayer = null;
   private function addLog(message:String):void
    log.text = StringUtil.substitute("{0}\n\n{1}", message, log.text);
   protected function onLoadButtonClick(event:MouseEvent):void
    addLog("onLoadButtonClick()");
    if (txtUrl.text.length > 0)
     initLayer(txtUrl.text);
    else
     addLog("Layer url is empty. Enter valid layer url.");
   private function initLayer(url:String):void
    addLog("initLayer()");
    if (activeLayer)
     gridProvider = null;
     activeLayer.removeEventListener(LayerEvent.LOAD, onLayerLoad);
     activeLayer.removeEventListener(LayerEvent.LOAD_ERROR, onLayerLoadError);
    activeLayer = new FeatureLayer(url);
    activeLayer.mode = FeatureLayer.MODE_SNAPSHOT;
    activeLayer.outFields = new Array("*"); // all
    activeLayer.addEventListener(LayerEvent.LOAD, onLayerLoad, false, 0, true);
    activeLayer.addEventListener(LayerEvent.LOAD_ERROR, onLayerLoadError, false, 0, true);
    dispatchEvent(new LayerEvent(LayerEvent.LOAD, activeLayer));
    addLog("onLayerLoad()");
    queryFeatures();
   protected function onLayerLoadError(event:LayerEvent):void
    addLog("onLayerLoadError()");
   private function queryFeatures():void
    addLog("queryFeatures()");
    if (activeLayer)
     var query:Query = new Query();
     query.returnGeometry = false;
     query.where = "1=1"; // all
     activeLayer.queryFeatures(query, new AsyncResponder(onQueryResult, ouQueryFault, activeLayer));
   protected function onQueryResult(featuresSet:FeatureSet, token:Object = null):void
    addLog("onQueryResult()");
    var queryLayer:FeatureLayer = activeLayer as FeatureLayer;
    if (activeLayer != queryLayer)
     return;
    gridProvider = new ArrayCollection();
    for each (var gr:Graphic in featuresSet.features)
     gridProvider.addItem(gr.attributes);
   protected function ouQueryFault(fault:Fault, token:Object = null):void
    addLog(StringUtil.substitute("ouQueryFault()\n{0}", fault.message.toString()));
 </fx:Script>
</s:Application>
AndrewThomas
ibespalov,
I think I'm wishing for something that isn't possible.
Just a bit of Background:
I'm trying to replicate this below in SampleFlexViewer:
Sample feature layer based on mapserver layer
But since the mapservice Layer in question is already loaded/added to the map object, I'm trying to get away with not adding it again to the map as a feature layer.
At the moment I am adding it as a feature layer with null symbol style and null outline, so the user can't actually tell that it's been added twice.
When I tried your code above, the fLayer_graphicAddHandler event is never fired. I guess this can't be fired until features(graphics) are added to the map. and this can't happen if the featurelayer isn't added to the map.
I think I will end up using your code for something else I want to do though, so thanks.
Thanks
Andrew
