Get Reference to Graphic Layer from Graphic
815
04-06-2010 10:44 AM
NateIrwin
I'm sure there is an easy solution to this, but I can't find a way to get a reference to a "parent" graphics layer from an individual graphic.
Can someone point me in the right direction?
MehulChoksey
Assuming you are using 1.x version for the ArcGIS api for Flex, Have you tried myGraphic.parent?
In ArcGIS  API for Flex 2.0 beta,there is a readOnly property called graphicsLayer that returns the parent as an instance of GraphicsLayer. This property is null if the graphic is not added to the Graphics layer.
NateIrwin
Perfect! Thanks. I am using the 1.3 release, and the parent property did the trick.
